Old 07-20-2006, 10:49 PM
TXSVX TXSVX is offline
AWD Ownz Joo
Did the dealership screw me? - Torque converter not locking up?
Hello all,
I was reading some old threads about TC's, trannys, etc and came across something one member said to another who was having TC and tranny woes.
They said "I hope you weren't the victim of the Legacy tranny in an SVX trick".
Well, I searched some more and couldn't find additional information. I'm assuming this is a trick (rip-off) the stealerships do sometimes when replacing a tranny in an SVX. Is that correct?
I'm asking b/c the original tranny recently went out on my '92 SVX after 136,000 miles. The stealership replaced it, but the car and the tranny definitely don't run the same as it used to.
1.) TC doesn't lock-up in 4th...ever.
2.) RPM's are much higher at highway speeds...2500rpm @ 60mph, 3000rmp @ 75mph, etc. (Most people seem to run 3000rpm @ 90mph). I seriously think my car would redline at 90mph right now in 4th.
3.) My hwy mpg sucks now...I used to get about 26mpg cruising on the hwy, now it's 18mpg.
4.) Excessive heat coming from under the dash and floorboards. The bottom of my seat actually felt like it was heated...like I had some kind of "cold weather seat package" option.
So was I "tricked" and now have a Legacy tranny? Just trying to gather some info before I go in on Monday and raise hell.
Thanks,
Kurt
(*sorry if this is in the wrong forum)
K.R.
'92 Ebony SVX LS-L
'91 GMC Syclone
'92 GMC Typhoon
Old 07-21-2006, 07:21 AM
immortal_suby's Avatar
Thread Killah
Its possible that they put in a different final drive tranny. Either that or your torque converter not locking could be the only cause of the raised rpm. You should see about 2000 rpm at 60 in lockup and that will go up by about 400-500 rpm when the torque converter is not locked.
A legacy tranny has a different final drive ratio than the svx so swapping one in requires the changing of not only the transmission but also the gears in the rear differential. If the rear diff gears are not changed then the awd will bind and eventually stop working. This happened to a member here and it was a long time before he realized his awd wouldn't work and that the tranny was from another car.
The svx final drive is 3.54. The legacy or impreza or forester range from 3.70 to 4.44. The low 3.54 drive in the svx allows for those 3000 rpm at 90mph cruises, while the taller gearing in the other transmissions will raise the rpm - like you are seeing.
It actually is common now and considered an upgrade to some to get a legacy or impreza transmission swap. People like them for the taller gearing which gives faster launches but it does heighten cruising rpm and will lower highway mpg. Part of the swap is changing out the ring and pinion gears in the rear differential to match the new tranny. You'll see many threads on here about 4.11 or 4.44 tranny swaps - these are the legacy and impreza trannys.
I would take your svx back to the place that did the work and have them figure out why the TC is not locking first without mention of the possibility of a legacy tranny in there. It could be something as simple as a temperature sensor. Once they have fixed the lockup issue check what rpm you are running at 60 and 90 - should be 2k and 3k and if that does not match then take it back in and raise hell.
good luck!
Locker Link
2015 BRZ Limited 6MT
Old 07-21-2006, 08:00 AM
Manarius's Avatar
Manarius Manarius is offline
Check out your rear differential. Is there a final drive stamped on it? What is it? Your numbers tell me that it should be a 4.11 final drive. In 4.11 final drive, you won't redline at 90....90 should be about 3800. Now, about the TC not locking up....the TC won't lock up until it reads a certain temperature from the TCU. Maybe the TCU is cooked and not telling it to engage. Either way, you need to go back to the person/stealership who replaced it and make them fix it.
I wouldn't believe a word that came out of a dealership's mouth. Legacy transmission being a downgrade? And what is the stock SVX trannny? Don't tell me that's a deal because those blow up all the time courtesy of their crazy-ass final drive. This dealership sounds like they think you're a fool and are trying to get your money.
-Jason
-Obi Wan Kenobi
Old 07-21-2006, 02:41 PM
AWD Ownz Joo
Thanks for the info guys.
I will look for any numbers on the rear diff.
The tranny also doesn't look the same as the old. It seems smaller than the original tranny that was in the car. The dipstick/filler tube is also different.
At this point, I'll be surprised if it's not a Legacy tranny.
K.R.
'92 Ebony SVX LS-L
'91 GMC Syclone
'92 GMC Typhoon
Old 07-21-2006, 02:47 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
From the outside there is no difference in size or shape between the SVX and Leg Trans.
Also, the rear diff will most likely still have the 3.545 tag on it but have different internals installed. Since the mounting studs are different between a Leg and SVX rear diff, it is much easier to use the original SVX rear diff cover.
Start off by getting them to correct the TC lockup. Then get back to us with an assortment of engine/road speeds.
Old 07-21-2006, 08:52 PM
Let us know what you find out.
