Old 06-24-2006, 09:35 AM
Dengue's Avatar
Dengue Dengue is offline
My kitten can woop your kitten
Send a message via AIM to Dengue Send a message via Yahoo to Dengue
fuel pump replacement
I think my fuel pump may be dead, I know there is an access port under the back seat, but when I looked up the part on advance auto parts it said something about having to drop the tank, is that correct? or can I just change it from the back seat?
Skip
'95 SVX L - Laguna blue 126,000+ miles
'89 XT - some sort of sun bleached blue
'00 Hyundai Sonata- charcoal gray (hers)
Old 06-24-2006, 12:54 PM
Old Fogey
There is a special tool, "Replacer"(42911PA000) listed in the book to remove the cap, as well as documented cautions re: venting fuel system, etc etc, but this is doable in the car. I'm sure our members have improvised a way to do it without the tool. I've thought about doing this to clean/replace the fuel sender(s) and straighten out my fuel gauge.
Glenn
Old 06-24-2006, 10:00 PM
it can and has been done inside the car
Old 06-24-2006, 10:12 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
if its any thing like the saab one i just did you have to tap on the ring it is screwed on and needs to be taped off i used a small hammer and a philips screw driver
- John
Old 06-25-2006, 10:08 AM
Dengue's Avatar
thanks alot, I'm hoping that the fuel pump isn't the problem, but, my diagnostic skills are pretty weak, I'll just for fun throw the symptoms out and see what comes back....
the check engine light has been on and off sporatically for about a month now, and the car is running a bit rough, sometimes, it doesn't start as easily as usual and a few days ago, it wouldn't start for quite a while, and then when it finally did in ran like it wasn't getting enough fuel, and then ultimately, it died. 2 days later, I started it again, and it sputtered like it was short of fuel again, then suddenly, it smoothed out and started running, still a little rough, and the check engine light is still on. even before the check engine light came on, I noticed that frequently when I started the car, I could smell gasoline in the cabin, and it smells like bad gasoline.
the only other thing I can think of is that it seems like this started after the car sat for about 2 months without being started. (I had surgery and couldn't really move around to get to the car)
hopin' for some insight!
Skip
Old 06-25-2006, 01:05 PM
Be sure to unplug it and then vent the tank before you start to take the plate under the back seat off.
