Lazy Turn signals
OK I have never in all my many, not as many as old Tom, years of working on cars had this type of problem
Every morning for the past 3 day my turn signals have not worked. 1st day about 80 deg in the morning. 2nd day about 76 deg in the morning. 3rd day about 70 deg in the morning. I drove my car twice before noon and they still do not work . They only start working after about 12 O'clock. ![]() ![]() ![]() I have been doing a lot of think on my thinking seat ![]() and i can not think of why it would act up like that. I have not checked the hazard switch yet, I will tomorrow. I can only presume that the relay is fluky, but only start working after lunch, WTF!??! Steve
92 SVX AWD 130,000 w/ rebuilt SVX 4.11 ![]() 97 Audi A4 1.8T (Daily Driver) 03 Ford Expedition(hers) SVXepidia SVX information warehouse Are you in? My Old Locker A 4.11 Founding Father "Tranny #6" I really need a manual ![]() Reading IX [SIGPIC][/SIGPIC] Ya I was there
Well my turn signals did not work again this morning. The temp was around 64 deg. I played with the switch and nothing. I pressed the hazard switch and they all blinked. Tried the turn signals again and they worked.
![]() I thought that the hazard relay and the turn relay were separate. Anybody have a thought. on this? Steve
Maybe reset the clock in the dash about 6 hours early???
![]() ![]() I don't know... thats an odd one...
stock wattage bulbs?
proper system voltage? any change if you turn the wheel? (poor connection to switch)
replacing the hazard switch might do it that is hooked up to the whole system and when it is unpluged turn signals dont work
Blinkers not working also
I have the same issue with mine from time to time, I have a 92 LS, with 64K, just about everything original. I just switch the hazards on, then the blinkers work again. I have gotten used to it. In the past year that I have owned the car, it has happened maybe 20-30 times. Bird
The turn signal switch provides direct individual circuits to the turn lights. The hazard switch a second separate set of parallel circuits and not a changeover arrangement. The hazard switch connects the flasher to alternatively, an only ignition on fused circuit, when in the off position and a direct fused circuit, when in the on position. This could be the circuit and set of hazard switch contacts to most likely have an effect. Switching to the hazard lights would have doubled the load on the flasher and could have overridden/cleared an intermittent fault within the flasher and I would bet on a faulty flasher unit as the most likely cause of your problem.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 06-02-2006 at 09:28 PM. |
Has anyone mentioned replacing the flasher relay with an electronic one? that has alway been the best option, they don't care about the load, they just flash. (they have a little lepricon in there that moves the relay for you)
Chris G 92 Pearlie, sold @ ~209k miles. Now owned by Tim. Current Ride, 1985 Honda Aero 80, stock 3024 klms |
Thanks Trevor.
I had to read it a few time, I'm a little slow at times ![]() Chris G. what are you talking about an electronic flasher relay. were could I get one to try. Steve
Any local auto parts sells the 2 and 3 connector flasher relays, in thermal and electronic.
The SVX doesn't use a custom flasher does it?
