Old 03-13-2006, 10:28 AM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
Send a message via AIM to SVX10 Send a message via Yahoo to SVX10
Steering Rack is Wack!
Need some steering rack diagnostic help.
Condition: Stock wheels & tires, Koni struts, K&B springs, slightly worn inner tie rod ends
Problem: When stopped (such as at a stop light), if I turn the steering wheel from lock to lock, it is not smooth. There's a "kickback" feel to it where, with constant input from myself, there is a variable resistance in the steering wheel that creates a sort of chatter as I turn the wheel. Then, toward the locks, the effort ramps up very high...to the point that I cannot turn it any more without rolling forward a bit. Then I get probably 15-20 degrees more before I reach full lock.
Any ideas or related experience from y'all? Rack? Rack valve body? Tie rod ends? PS Pump?
Mat
Time for my very own long list of mods:
92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler
I don't care if Subaru says it's STI...it will always be STi to me
Old 03-13-2006, 01:18 PM
Earthworm's Avatar
Meow!
Well before we dig too deep, how's "the o-ring"?
Old 03-13-2006, 02:08 PM
Phast SVX's Avatar
Phast SVX Phast SVX is offline
BOOOOOOOOOOOOOOOOOST
Send a message via AIM to Phast SVX
100% the o ring. Do a search for it, takes a few minutes and costs less then a buck(assuming you have a turkey baster you can steal!)
phil
~Phil
Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog.
Old 03-13-2006, 04:59 PM
SVX10's Avatar
o-ring is done...first thing I did. Also replaced the PS hose coming between PS resevoir and PS cooling circuit. Done with OEM subaru washer, even. Any other ideas. fluid level low? The dip stick looks good, but I could probably add about a half quart without the level going up at all. I hate that dip stick.
Old 03-13-2006, 05:19 PM
Earthworm's Avatar
Meow!
If that's the case either you have air in your system or that fluid is leaking out somewhere.
Old 03-13-2006, 09:13 PM
intelisevil's Avatar
intelisevil intelisevil is offline
<<<Alcyone
Mine felt similar to what you're describing just before the crankshaft pulley completely seperated.
Dan
Old 03-14-2006, 11:00 PM
triumph1902's Avatar
triumph1902 triumph1902 is offline
In order to get the air out you turn the wheel completely to one side than all the way to the other several times slowly. Take the PS reservoir cap off...If you have air, bubbles should come up there. Sometimes it even foams.
One thing you can do is: While having the car running and on the ground turn the steering wheel abruptly from side to side (not all the way)...changing direction quickly. If you get major kickback or feel a loss of power steering your pump is not giving enough juice...if everything is fine then there could be something wrong with your rack and pinion.
Old 03-15-2006, 09:06 AM
SVX10's Avatar
Thanks,
I'll check those things out.
