Old 02-13-2006, 05:30 AM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
Question Transmission difference problem?
I have recived my 94' 4EAT from japan, looks nice and doesnt smell burnt like mine , only problem is that it has, what i assume to be, a speed sensor in the front diff, my 92' 4EAT does not, it this going to cause major problems, or can i wire the box up the same as my original box, negationg the front diff sensor??????
Cheers
Jake
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
Old 02-13-2006, 04:29 PM
oab_au oab_au is offline
Cheers
Jake
Gid'ay mate I thought that it would have the sensor in the front diff, instead of in the transmission. Don't know why they would keep it there, it the latter boxs.
The wiring that runs down to the box has the sensor wires at the plug. You need to run these wires to the sensor in front diff. I am sure that Phil (b3lha) has sorted this out, before. Send him a PM. If he can't help, I'll scan the wiring.
One Arm Bloke.
Tell it like it is!
Old 02-13-2006, 11:04 PM
-JJ-'s Avatar
Endangered Species
I have a speed sensor in the old box, in the transfer case, there is the same sensor on the new box too, aswell as the sensor in the front diff??
Old 02-14-2006, 04:24 PM
Hi Jake, there are two speed sensors. The No.1 is inside the rear section, of both types of boxes. The No.2 speed sensor on the Aust box is inside the box, at the parking gear. In the JDM box, it is on the front diff.
You need to run the three sensor wires from the plug, that the box plugs into, to the sensor in the front diff.
Looking at the plug that the box plugs into, there is 16 holes, the sensor output is a white wire at pos. 15. The black is at pos.14, and the brown is at pos.8.
I don't have the diagram of the wiring, to the JDM/US No.2 sensor to tell what the colour is.
One Arm Bloke.
Tell it like it is!
Old 02-14-2006, 04:39 PM
-JJ-'s Avatar
Endangered Species
?? what do you mean ??
Do you mean the order they attach to the no2 sensor on the box??
also i have just pm'd Phil
Old 02-14-2006, 06:20 PM
I don't have any info on the wiring of the No.2 sensor that is mounted in the front diff. I can't tell if the wiring for that sensor is connected through that plug, or has a different loom and plug for it. I just guess that the wiring colours are the same as the Aust sensor.
One Arm Bloke.
Tell it like it is!
