What to do, What to do??
Ok so most of you know i have no more transmisson, the following are my options: (prices in AUD)
1) Rebuild: svx 4eat, between $1800 - $2250 2) Purchase 4.11 4eat (with diff) for $1200 (has 104000kms on it ![]() 3 ) Purchase a JDM 4.44 4eat (with diff) for $900 (from a trusted friend) from a 96-97 legacy TT (GT) *ok so i need to know wheather option 2, and 3 autos can plug and play? or do they use different wiring harneses?? *also what exactly does need to happen with the drive shafts, i know they need to be modifyed, but in what way?? *also when and why do you need to install a 20ohm resistor?? if some one dosent mind posting that would be nice ![]() ![]()
1992 Pearl / Black SVX removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads Last edited by -JJ-; 01-03-2006 at 10:39 PM. |
You might PM Huck or Tom and see what they think. They would have a better idea on what to do. Good luck.
Option 2. $1200 will grow to about $1800 or more, by the time you lengthen the drive line (our box is longer than the US model), fit the rear diff gears in, and supply a Liberty TCU. You will lose the 36%/64% torque AWD. Option 3, Too low a ratio, good for driving around Tasmania. ![]() The 20 ohm resistor is to replace the 10 ohm dropping resistor, behind the battery, to raise the line pressure a bit. Harvey. ![]()
but i have plans do do cam work..... didnt u specify the need to have a 4.11 or 4.44 to do that sort of work (incresing durations etc)?? or can i do the cam work on the stock ratio?
Also option 1 was a quote from the builder of the rigoli wrx auto box basically i dont wanna get the stock box fixed now if later i need to change it again to do the cams
1992 Pearl / Black SVX removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads Last edited by -JJ-; 01-04-2006 at 02:57 AM. |
then use the 4.11. decide now. If you want to go lower ratio, get them to rebuild it with the 4.11 front diff, and fit the 4.11 in the svx rear. Honestly I think the rebuild, by them, well make a bullet proof box. The SVX box has a stronger high clutch and better AWD than the four cylinder boxs. Harvey.
Option 3 is the easiest and simplest option, yes the 96-97 EAT is a "plug and play" box for it, and the Legacy TT has the same stronger high clutch as the SVX, and the lower final drive will make it easier on the tranny too (plus a 4.44 SVX is WAY more fun to drive ![]() Granted I'm not down under, so I'm not as sure of the differences in the trannys down there....but either way installing another auto is the easiest fix, plus you get the added performance of the lower ratios. Just my thoughts on it....
4.11/4.44 for around town and racing. stocker for highway. You can make cams to suit your driveline not driveline to suit the cams
Tom |
