Old 10-17-2005, 12:32 PM
THAWA
Brake specifications
Does anyone have access to a FSM or something so they can help me?
I'm looking for:
Front Caliper Piston Diameter/Radius: 42.8mm/21.4mm
Front Rotor Effective Diamter/Radius: 253mm/126.5
Rear Caliper Piston Diameter/Radius: 38.1mm/19.05mm
Rear Rotor Effective Diameter/Radius: 254mm/127mm
Thanks.
Old 10-18-2005, 07:04 PM
THAWA
Anybody there?
Old 10-18-2005, 07:17 PM
wawazat??'s Avatar
Yeah, I'm still around
Per the FSM
Front Caliper Piston Diameter/Radius: 42.8mm x 2
Front Rotor Effective Diamter/Radius: 253 mm (OD 302mm)
Todd
Down to none
Old 10-19-2005, 01:00 AM
THAWA
Jawesome, thanks much!
Old 02-14-2006, 05:16 PM
Legacy777
Hardy,
I know this thread is ancient, but can you or Todd provide the rear rotor OD?
Also, by looking at those numbers and what I have in my spreadsheet
http://www.main.experiencetherave.co.../brakemath.xls
The front rotors are larger then what the WRX even currently received. Has anyone verified the FSM data? It just seems a little suspect to me.
Thanks
Josh
Old 02-14-2006, 06:57 PM
THAWA
It's all accurate as far as I can tell.
I posted what the rear rotor diameter is on nabisco.
I wouldn't be suspicious. The SVX had the largest diameter front rotors of any Subaru up until the brembos. You should see the pads, not that it really depicts rotor size, but they're huge. The rear were the largest up until the 2 pots/BE/BH I forget which came first. The front thickness is huge too, 28mm, BL/BP size. And apparently the JDM spec SVX's had 290x18mm rear rotors, VENTED! Hell of a braking system.
