WTB power steering pump
I have a '92, not sure if it matters though.
Gimme.
Brian |
We all assume you've changed the o-ring and that's not the problem right?
If you have not, that would be the first thing to do. There are very few pumps that actually fail. Most of the ones replace are done so without fixing the very easy things to do.
Well the fluid is topped off and has stayed that way but it makes an annoying whiney sound. Also the p/s will give out here and there making the wheel real sluggish to turn. Will an o-ring fix all this?
Brian |
Yes, it usually does. There are many symptoms that occur. I would replace the O-ring first and then see what you have. Find the How-To in the folder here. Good luck and let us know what you find.
My car deveolped a problem with pretty much the same symptoms as Ricochet's: Almost 3 weeks ago, after the car sat for 2 weeks, a belt started squeeling. I especially noticed it when steering, and the p/s would sometimes jerkily cut out-and-in when turning the wheel sharp, especially while pulling out of a parallel parking space. I finally got around to checking the belt, which I'd just changed in June, and it didn't seem loose, but the belt was hot after just a few minutes of running. I tightened (or possibly loosened) it just a smidge anyways. I also noticed at this time, that the pulley would intermitently "stall" while I cut the wheel. I feared - and was told - that my p/s pump was going bad. Then I checked this thread and it's prequel. I replaced the O-ring today, used Dexron III ATF to replace the fluid I'd siphoned out, and drove my car for about 40 minutes. The squeal has not entirely disapeared, though. (When I looked under the hood and had someone turn the wheel, the pulley wasn't stalling, even during the squeal.) I'm not sure what to think now.
