Old 03-13-2005, 12:37 PM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
Question Aftermarket Lugs...who knew?
Who knew you had to have aftermarket lugs with your new wheels? Not me apparently. Anyhow, I just bought a new set of Enkei 18" wheels and some pirelli 225/40/R18 tires and had everything put together and balanced, and went to put the wheels on the car myself to save some money in labor, only to find out that i would need special "thinner" lugs and special key or something like it for the wheels. So I went around town, looked up the svx lug size (12mm x 1.5) only to find out that no one sells anything like this, and I have no idea where I am supposed to find this stuff, and what I will need. When I search on ebay for those spec numbers, quite a few options present themselves. This being said, I was wondering if anyone could help me find the lugs I need so that I can attach my whels, I am excited as all getout. FYI, the wheels are Enkei CP1 or CP01 if that helps. Thanks all!
-Andrew R.
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
Old 03-13-2005, 12:54 PM
Weasel 22
having owned several sets of Enkei's..ive never been able to use the stock lugs on them..on all instances ive used the supplied Enkei lugs to mount the wheel..I have a set of Shoguns coming and the supplied lugs are 'supposed' to fit my SVX..as they have on another SVX here with Shoguns..my wheels should be here in a few days..I'll post back on the results
Old 03-13-2005, 01:06 PM
Hmm
Since I got all four wheels second hand for $325, I guess that explains why the lug kit didnt come with it...unbeknownst to me. Any suggestions on where to buy the enkei set, or if anyone here as a set I can use?
Old 03-13-2005, 01:40 PM
Weasel 22
in my area I use Les Schwab for tires and service..I really like Toyos..they should have a proper set of lugs on hand..I would assume any tire shop worth their weight should
Old 03-13-2005, 02:31 PM
Can't say that I've ever heard of Les Schwab before. Ive asked around in my town, and they all carry some type of lugs or another...but none of them are narrow enough to get a socket around when they are in the wheel...btw...the "tuner" lugs that you can buy on ebay...are they narrower than typical lugs...is that what i need? I was kind of irritated because I found the perfect set of Enkei lugs that i needed on ebay, but they are gold, and my wheels are silver.
Old 03-13-2005, 02:43 PM
Weasel 22
in general the tuner lugs are narrower..to fit in the Enkei wheel holes you will need them..to fit the SVX? thats a question
Old 03-13-2005, 01:32 PM
Where did you find those? They don't make them anymore. They are one of my favorite after market wheels. Enjoy them.
Old 03-13-2005, 01:38 PM
Weasel 22
I had a thread on those I was looking for the Arashi and ran into those on ebay, actually 2 sets of 5 lug universal showed up on those..I had bid on the first..and was in a bidding war on them when a second set showed and the other bidder bought those..lucky me they are my all time favorite as well..you can adore them when I come up for a meet up there
Old 03-13-2005, 01:39 PM
Does the place you got the shoguns from have more lugs?
Old 03-13-2005, 01:42 PM
Weasel 22
I believe he wouldnt since he sold me them however if you search Enkei wheels on ebay they usually have lug sets for them..hope that helps
