Rear wheel bearing
Can anyone provide me with the pat number or bearing number for the rear wheel bearing? Local Subaru agent are playing hard to get!
Dave@Partacoona.freeserve.co.uk |
Try a US internet company like 1stSubaruparts.com or Motorsportwarehouse.com
Andy ------------------------------------------------------------------------------------ If I would be a young man again and had to decide how to make my living, I would not try to become a scientist or scholar or teacher. I would rather choose to be a plumber or a peddler in the hope to find that modest degree of independence still available under present circumstances. -- Albert Einstein, The Reporter, November 18 1954 |
Re: Rear wheel bearing
These are the parts numbers I used when ordering mine: Rear Bearing [L or R] 28016PA010 Outer Seal [L or R] 906250020 Inner Seal [L or R] 28015AA021 Snap ring [L or R] 28035AA010 Hubs [L or R] 28052 PA010 If the person doing the job for you does not use a proper pullers, they can deform the hub, and new bearings inserted will fail quickly. Otherwise you should not need a hub. Snap ring might be OK if you don't break it. They are cheap enough so maybe better get a new one. You DO need to get the inner and outer seal though. Also, and VERY important, remove the packing grease the bearing comes wrapped in, and fill the bearing with proper bearing grease. {Because mechanics kept installing the bearings with the packing grease, and the bearings kept failing, Subaru decided that all bearings would come wrapped in the proper grease. This happened maybe '99. Because you have NO idea how long the bearing they send you will have been on the shelf, carefully remove all the grease in it and pack with proper stuff before install. You have been warned} Joe ![]()
Oh, and Andy is right.
Go onto www.subaruparts.com, go into SVX, quote the year, and check the part numbers I listed are correct. I think they will be. Joe ![]()
Do you know the part number for the bolt that connects to the wheel bearing? Mine is rusted and has to be torched off.
The bolt is connected to the lateral links (if that helps). |
joe2rule,
If you mean the long bolt through the wheel bearing housing that attaches the lateral links it's; 20540AA000 with nuts; 20550AA010. Glenn
YES! Thank you!
