tranny fluid change
I need to change the fluid in the tranny of our '92 LSL with 160k (not a flush) and wondered how much fluid and what type should I get? I do have the external filter which may require more fluid?
Tdog |
Should be able to just replace what you drain out, as not all of the fluid will drain from the tranny. I think it's only going to be 4qts or so. I can check my manual when I get home. Otherwise, do a search, I know the info exists in another thread that I actually started some time ago...
-Mike '92 Pearl LS-L (sans Spoiler) #0993 Mfg. 5/91 "It says here, 'Breakfast any time'... That's right... In that case, I'll have the pancakes in the Age of Enlightenment..." |
Best way to do it is to measure the amount of fluid you drain and replace that same amount. The owner's manual says 4qts per change - with the trans having a 10qt capacity. Some members have been able to drain 7 qts by putting the front-end up on jack stands and letting it drain for ~ 1 hour.
-Chike
I always use wheel ramps and I usually have to put in 6-7 quarts.
- Jim |
I jack up the passenger side (the drain is on the driver's side) and get just at 7 qts consistently.
Not to be OT, but how do you get ramps under the front end, I have had no luck in trying to roll the car up onto them? Am I missing a secret front end ground clearance hydrolic thingamabob?
Regular yellow ramps with two 2X4s about 2 ft long. It makes the ramps more gradual.
![]() - Jim |
Check these out. Turned my very frustrating set of ramps into very easy to use tools.
http://www.subaru-svx.net/photos/user.php?RojoRocket|20012 oops! view "ramp pics" Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket Last edited by RojoRocket; 09-23-2004 at 12:27 AM. |
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd ![]() 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
Having wood makes it much easier to keep it up. ![]() |
Haha. Good point Boondock, thanks for the tip
![]() Rojo, did you build those or buy 'em? I'd love to get a set. My jack struggles to lift the beheamoth! ![]()
-Mike '92 Pearl LS-L (sans Spoiler) #0993 Mfg. 5/91 "It says here, 'Breakfast any time'... That's right... In that case, I'll have the pancakes in the Age of Enlightenment..." Last edited by Whoru465; 09-23-2004 at 11:05 AM. |
