Old 04-20-2004, 09:10 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Question Does this SVX have Lowering Springs???
Okay, I'm looking at purchasing this '96 SVX L from a dealer here in VA on Sat, May 1st and I've already taken her for extensive test drives. She runs great, tranny shifts perfectly and is in top condition considering the 95K miles on her odometer.
However, when I was looking her over, I noticed that she sits kinda low to the ground and there isn't much gap between the tires and the body.
For comparison, here is Mychailo's SVX which is lowered a 1/2 inch front and rear:
Thanks!
2006 Steel Gray WRX TR (sold)
Old 04-20-2004, 09:48 AM
mark10t
(Ahem) (right front wheel)
If this car doesn't have a 'matched set' of wheels on the other side, there's trouble.
....but to answer your question- it doesn't look lowered to me; they all sit that low.
-Mark
Old 04-20-2004, 09:58 AM
Chiketkd's Avatar
The right front wheel? Do you mean that it's on backwards?
The wheels on the other side are the stock 16", but I'm not sure if they are reversed in the same way. Will look into it though...
Thanks!
Chike
P.S. Why could it be trouble?
Old 04-20-2004, 10:08 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
the rims are directional....
You MUST have 2 set of 2. Two for each side. There is a good chance that they put it on wrong at the rotation. Who knows...
why directional? They bring air in to cool the brakes down a little.
As for the height, the only way to do it is to measure it. But every svx has a slight height issue. They are different from use and who's in it etc.
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 04-20-2004, 10:33 AM
LarryIII LarryIII is offline
Seraph,
Since I've been doing the lo-carb thing my SVX keeps riding higher and higher. It's quicker and gets better milage too.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 04-20-2004, 10:54 AM
Chiketkd's Avatar
Seraph,
I saw this 94 L in your locker:
Were the rear wheels put on backwards on purpose and did you have any ill-effects from doing this?
-Chike
Old 04-20-2004, 10:57 AM
mbtoloczko's Avatar
sans SVX
If you have access to an accurate measuring caliper, the easiest way to check would be to measure the wire diameter of the springs.
Stock front: 0.565"
Stock rear: 0.505"
Be sure to clean off as much crud as possible from the wire, and measure the wire from an angle where the curvature of the wire has no effect on the measured diameter.
Mychailo
Visit my locker
Old 04-20-2004, 10:59 AM
Chiketkd's Avatar
Awesome! Thanks a million. I'll definitely check that out when the SVX is on level ground!
-Chike
Stock front: 0.565"
Stock rear: 0.505"
Old 04-20-2004, 11:14 AM
SubaSteevo's Avatar
No longer blue member
Putting the wheels on backwards has no major negative effects:
It would A) *possibly* reduce brake cooling slightly, B) look strange, C) result in getting made fun of for having your wheels on backwards
I think Mark meant that one wheel could have been replaced with an incorrect wheel so it could have 3 left wheels. As long as the other side has one wheel backwards as well there are no problems (unless the tires are unidirectional and were put on backwards) except visually.
-Steve
01' MSM Lexus IS300
Old 04-20-2004, 11:16 AM
mbtoloczko's Avatar
sans SVX
-Chike
It will be much easier if you can get the shop to put the car on a lift.
Mychailo
Visit my locker
Old 04-20-2004, 01:49 PM
alltrac alltrac is offline
How much do they want for this red SVX???
Victor
Old 04-20-2004, 01:55 PM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
Another possible reason that it seems to be sitting low is that one or both of the rear strut mounts could be bad.
Old 04-20-2004, 02:04 PM
Chiketkd's Avatar
They are asking $7966, but I've talked them down to $7000.
-Chike
Old 04-20-2004, 02:07 PM
Chiketkd's Avatar
I thought about that, but after driving it for over a 1/2 hour during my last trip, I seriously doubt. The ride is not lumpy and the car corners flat.
My wife's old car, an early '90s 240SX had some bad struts, and I definitely know what it feels like to drive a car around with a damaged suspension.
-Chike
Old 04-20-2004, 02:14 PM
nubs's Avatar
Multiple Suby Owner
-Chike
I just recently found a bad strut mount,not the strut itself, on my car. It rides and drives fine. It only sits lower.You can look under the car to see if the spring is up against the body or if there is a gap in between the spring and the body.This seems to be a common problem if the car has spent alot of time in a snow belt state.
