Old 10-22-2003, 11:01 PM
Breck SVX
Tranny Cooler
I've been meaning to do this since I got the car. Having just been hired at a Subaru dealership now seems like the appropriate time. I'm gonna have a mechanic install the cooler for me as; 1. I'm too lazy and 2. I dont have the resources or time(lame excuses you say? yes!). I think I've found all that I need but I just want to make sure with you guys.
Summit Racing:
1. PRM-10678 (perma cool filter)
2. BMM-70268 (b&m cooler)
3. ATM-2640 (auto meter gauge)
Sub Total: $119.85
Questions:
-do i need some kind of sender for the temp gauge? If so where can I find it?
-are the combination of these 3 things the most efficent and cost effective way of keeping my torpid tranny cooler?
-if not what else should i get?
-should I have the cooler mounted in parallel?
-best location for the cooler?
thanks,
-Alex
Old 10-23-2003, 12:03 AM
mbtoloczko's Avatar
sans SVX
Re: Tranny Cooler
Originally posted by Breck SVX
Questions:
thanks,
-Alex
- The sender will be included with the gauge.
- I have a similar setup on my car. It works pretty well, but it still gets hotter than I would like in the summer, and the ATF is too cool in the winter.
-My suggestion is to install an ATF cooler with an electric fan into the left-front wheel well. Get the thermostat and wire the fan to kick-in based on the thermostat. Some people have done this with good results.
- I think that series or parallel will give similar results. Some people feel that parallel is better because there will be a smaller pressure rise across the ATF cooling loop. If you have an early model car ('92-'93), it would probably be best to stop using the radiatior cooler. These coolers have a tendency to clog.
- If you use the cooler you listed above, the ideal location for most effective cooling is in front of the a/c condenser.
Mychailo
Visit my locker
Old 10-06-2004, 09:09 PM
Breck SVX
So i got all these things today, took a while to save up but they're here! The perma cool instructions refer to a 3rd port for a sender, I dont see a 3rd port. How did you guys attach your sender to similar setups?
thanks
-Alex
Old 10-06-2004, 09:35 PM
AFBeefcake's Avatar
AFBeefcake AFBeefcake is offline
Subaru Swapper
Send a message via AIM to AFBeefcake
There is a hole for the sender in the top of the filter bracket. In between the inlet and outlet.
2005 Legacy GT
2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles
My WRX's Cardomain Page
Old 10-06-2004, 09:46 PM
Breck SVX
I dont have that hole, there is a little indent but no hole...does this mean i'll have to drill and tap one?
-Alex
Old 10-07-2004, 09:14 AM
AFBeefcake's Avatar
Subaru Swapper
o? I don't know that hole should be there. That pic is of the kit you orderd (PRM-10678) right from summit racings web site, and I have the same one on my car and it has the hole.
2005 Legacy GT
Old 10-07-2004, 10:28 AM
Breck SVX
Thats the part # I ordered but the hole is definetly not there. I guess I'll have to call summit.....
k, just called...they sent me the wrong part but the right one is on the way.
Old 10-07-2004, 12:17 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Check my locker for pics on installing a trans cooler in the driver's fender well. I also have the PermaCool filter, which you'll be able to see in a couple of the pics. FYI - I removed the bracket that holds the stock trans filter in place. This was a bear, as it uses the same three bolts as the car hold down loop does, which have locktite on them!
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-07-2004, 01:51 PM
Breck SVX
For those who mounted the cooler infront of the condenser, did you take off the bumper cover?
-Alex
Old 10-08-2004, 02:33 PM
SVXRide's Avatar
You don't have to take the bumper cover off. Removing the radiator makes it very easy...
-Bill
Old 10-08-2004, 04:10 PM
rob_4187's Avatar
rob_4187 rob_4187 is offline
You're mine!!
Send a message via AIM to rob_4187
What does a tranny cooler do for your car (besides cool the tranny)? Does it improve performance or give you a higher rev limit?
Old 10-08-2004, 04:40 PM
Earthworm's Avatar
Meow!
Neither...it makes your tranny last longer. (MTBF)
Old 10-09-2004, 03:05 AM
nsm484's Avatar
nsm484 nsm484 is offline
Teh Geek
Send a message via ICQ to nsm484 Send a message via AIM to nsm484 Send a message via Yahoo to nsm484
My 92 has a Basicly New Radiator on it... If I invest in a tranny cooler, should I go ahead and Bypass the Radator Tranny cooler... or keep it sence its new?
Also.. is it worth it to flush the tranny fluid, and redo with all clean fluid when I invest in a Tranny Cooler/Filter, etc?
Note: Miles on car, atleast 135,000+ (Speedo hasnt worked sence
i got the car, so this is an est. miles... im sure its around this area though)
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker
2002 Mitsubishi Lancer OZ Rally [Nori]
1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling
1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone)
1992 LSL Ebony Mica (Sold to svxcuseme)
Old 10-09-2004, 09:53 AM
n00b on demand's Avatar
I suggest you just put the cooler inbetween the radiator and a/c condensor. Its alot easier to install that way. When I put mine in i didnt bypass the radiator. Yeah its a good idea to get a fluid change or flush before you put the cooler in. Its just another way of being safe.
Old 10-09-2004, 08:29 PM
SVXRide's Avatar
You can plumb in your cooler in series if your radiator isn't the original one (if it is, it will have the infamous "screen" in it which can restrict ATF flow). If you've still got the original radiator, I'd recommend bypassing the radiator.
-Bill
