Sluggish start
hey hey hey there
ok, i just checked my check engine light on my 92 LSL and it said my knock sensor, but does this have somethin to do with my sluggish start? the sluggishness only happens sometimes, no consistancy. Usually when i leave work. ok, one other thing. im sure its easy, but when my engine is cold, a belt squeals when i turn. Serpentine belt? or what is it. Thanks guys Pat p.s my rotors are shot. i wish i had money |
Pretty good set of drilled/slotted rotors on ebay right now from a guy called skeptikal in CA for $235(buy it now). I just put em on my car with ceramic pads, and they seem pretty good. There's also a set from i-rotors for $279.
They're both pretty good prices for 4 new rotors. Just a little FYI, Dave
Dave |
replace knock sensor, not one but both
white leathers, h.i.d, ecutune S/C stage 4, 14 inch 2piece rotors big brake kit., , msd ignition, c/f dash kit, front spoiler,carbon fiber jdm rearc wing,19 inch rims, nos, , aem fuel regulater, koni-gc package, ported cylinder heads, supercharger cams,solid buck and shims,wrx sti intake valve and exhaust valves,& valve springs, gas analizer,water injection, exhaust temp gauge, idiglo gauges, shift kit, , remote start, all automatic windows,2.5 inch true dual exhaust system with crossover, and 2 borla stainless steal muffler,air filter velocity air stack 3inch to 6 for air filtre, group n mounts, momo steering wheel, dyno will happan soon |
two accessory belts on the svx: power steering and air conditioner.. remove the belt shroud and examine the underside of both for cracks.. if they both look fine, you might just need to tighten the PS belt a little
-adam |
