help very rough idle
got a question here. i have a 94 svx
for a while when it gets really cold my car would start but idle like it's runnin on 2 cyl. i can smell a lot of gas not getting burned so i tried almost everything tps, ecu, maf, water temp, etc etc i gave up and bought another engine with 80 K from a place that imports em from japan so after i dropped in the engine did valve cover gaskets rear main seals etc to prevent future oil leaks.,.and regular maintance things like oil change spark plug fuel filter etc anyways car was running fine for the last month until recently i had some stalling issues which come and go and now it's now starting properly again. i crank crank it would start run like ****. i give it some gas it stalls. crank crank it starts runs like crap i give it gas and once it passes the 2-3k range it would run fine and then back to idleing fine and afterwards if i turn it off and start again it would run fine and it seems to happen so randomly. like today it started fine and down the street i try to gun it to make a light and it would cut out and barely make it pass the light it would stall and when i try to start it it would run like crap and after some gas + crank it would be fine again any ideas??? |
Have you checked for codes in the ECU?
When was the last time the O2 sensors were replaced? -Bill
i haven't checked the O2 sensor actually. but was told by many mechs that the o2 sensor wouldn't cause bad starting. it'll only be once the engine is running and warms up...
also we did a test by unpluggin the o2 sensor and there was no difference... i haven't checked for codes yet. waiting on my friend being free to hook it up to the comps. but no chk engine light except when it's idling rough which could be just general engine misfire code only thing i've thought of is maybe fuel pump has a bad ground and cuts out randomly?? or fuel pump relay is going anyone have this problem before? |
cam sensor
A bad cam position sensor will act this way (it did with mine).
But even though the CEL goes out, it is stored in the ECU. Once I read mine, it told me exactly what part to replace, the CPS. Read the codes - they are there and it will help lead you in the right direction. |
just wanna give everyone an update
i did a CEL check and it showed up 10 codes egr valve, oxygen sensor #2,TPS,MAF,cam sensor, water temp,fuel injector #6 etc so i was like it couldn't possibly be all that sensors went at the same time on this new engine... so checked all wiring.. couldn't find any problems anywhere swap ecu and it was all cleared and haven't had the mysterious svx stalling problem since thanx for everyone's help mike |
Glad to hear you have the problem sorted. These type of things can drive you NUTS!! ![]() ![]() ![]() ![]() It is actually common for nearly every check engine code that the troubleshooting path is: Check the signal and the earth for the sensor Check the wiring to and from the ECU Check the connectors are good. If everything checks out, the next suggestion is usually "Replace ECU" For sure with all your codes coming up together [Christmas!! ![]() ![]() A question; you replaced the engine with a jdm import. Did the import come equipped with EGR and emissions gear? And if it didn't, did you just do without, or port over the gear from your old engine? OK that's two questions. ![]() Joe ![]()
