Power Steering line location 1992
I need help locating the correct positions of the power steering lines at the pinion housing. Specifically, the short line that connects on one end to the center of the rack. I have the other end connected to the second hole from the bottom on the pinion housing. I'm not sure if this correct. Can anyone check their car and let me know?
Thanks, Walt Weems |
Re: Power Steering line location 1992
I am not sure I follow which lines you are talking about. I know it would be hard to describe and I am a visual person so picture is worth a thousand words. I have the one I got from Tom still on my garage floor so if it is the short lines that are part of the rack then I can check that, if it is the other two lines that are strapped to it I believe (memory is fuzzy) those get routed up front for the power steering cooler.
Let me know if you need me to check into it further I have a manual at home that may show it or give enough info for you to be able to figure it out. Last edited by sowise; 12-08-2009 at 02:07 PM. |
I have a great picture. 1.5mb , butI can't post it. Can I send it to your email.
Thanks, Walt |
Check SubaruParts.com .... They have parts diagrams for almost everything. I know they have a good pic of those relationships (steering section).. . Register, open, see! [Choose OEM parts, SVX 2/4 WD, YEAR after logging in.]
Jim ![]()
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() |
