Name this front suspension piece, please.
Front driver side piece with the 3 bolts that supports the tire/rotor/brakes (knee assembly?), what is this piece called so I can order it if it's still available? It got bent about an inch back in the accident and needs replaced. Thanks in advance....
1994 subaru svx le 112k Last edited by Subix; 11-14-2012 at 08:07 PM. Reason: e2 |
Re: Name this front suspension piece, please.
P/N 20200PA100 Lower arm assembly (RH)
P/N 20200PA110 Lower arm assembly (LH) from subaruparts.com approx 300.00 each. If I were you I would order a set of ball joints that mount to the 3 bolts also...they are fairly easy to replace. |
That's the control arm. Just have them swap the one from the bordeaux.
Sad as I had one replaced on the suzuki not too long ago and for the life of me couldn't remember the name of it. Thanks and yeah my concern was getting the bordeaux once they take it off as I'm unsure they'll mess with putting the bad one on it but I don't know. Thanks again...
1994 subaru svx le 112k |
