AC Problem
My ac wasnt blowing cold so i got a recharge kit fot it. I got the R134A conversion kit and when i finished it blew cold for about 10 minutes then after that I started hearing a clicking noise from under the hood and the rpm's were bouncing from 900 to 800 in idle. The ac compressor is stopping and lifting as the belt spins. It didnt do it until the very end when i put the last can in. Could it be that i charged it too much? I ran it for a few days with the ac on full and it blows hot air and still drops the rpm's. I talked to a shop and they said it might have contaminated the whole system. Any suggestions?
Teal 92 SVX LS L with 103k Engine: Stage 1, 3 in filter with heat sheild, underdrive pulley, NOS fogger system (75 shot)to be installed soon Sound:1 10" infinity with 230 continuous watt Dual amp (we have small trunks) |
Sounds like your compressor is seizing up, it may not be much longer for this world. Did you follow the instructions and have the system evacuated before filling? Also it is recommended to change the drier canister when you do the conversion.
The 92 AC system is supposed to hold 21-25oz of R12, which translates to 16-20oz of R134. The conversion kit I got had 3 15 oz cans, so if you used all 3 cans and didn't have the system evacuated first, then it is probably under way too much pressure. If you're lucky, the compressor might still work ok once the system is purged and refilled properly. If not then well, I hope you have deep pockets or room for a lot of ice packs in the freezer. KuoH Last edited by kuoh; 06-10-2005 at 10:40 PM. |
You probably didn't get enough coolant into it. I have done this before and if there is not enough in it, it will shut down and not cool. If you try to put more into it, it will click again and then start working. Give it a try, and I think that will work.
I doubt that. The SVX has a small capacity AC and if he used every can of the retrofit kit, then he has way too much refrigerant, especially if the system wasn't evacuated first. Too much refrigerant is just as bad as not enough, plus the SVX has an under pressure switch that prevents the compressor from running when the level is too low. Also it wouldn't sieze and cause the belt to skip when shutdown, because it just releases the clutch. I don't know if it has an over pressure switch though.
KuoH Quote:
I purged all of the other stuff out before i refilled it. All i used was about 2 1/2 of the cans that came in the kit. Should i purge some of it out or all of it for that matter? Thanks for the replys
Do you have a pressure gauge? If you do, put it on the LOW PRESSURE side and tell us what you see.
What do you mean by purge? Did you just release the pressure or actually have it evacuated? There is a difference, as an evacuated system is under a vacuum. What size were the cans of R134? The 92 SVX holds a max of 25 oz of R12, which translates to about 20 oz of R134. Just releasing the R134 isn't going to help, as you likely have air in the system and the compressor is probably damaged. Best thing now is to shell out the bucks and have the AC system cleaned and refilled since you may now have metal shavings in the system. If that doesn't work, you're probably looking at a new compressor and might as well replace the drier too.
KuoH Quote:
