After aceleration, cars turns off
Hi Guys,
My name is luiz, i´m from Brazil. My car After full aceleration the car turns off. No errors. What is it? Could you help me? |
Re: After aceleration, cars turns off
If you mean, after holding the throttle pedal fully down, you should check the throttle position sensor/unit/indicator, full instructions have been posted here.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 02-14-2022 at 07:37 PM. Reason: clarification. |
Thank you Trevor. That is it. After full throttle, when i leave the pedal the car tuns off. I´m going to find the the throttle position unit. Regards |
When the motor is cold, it´s not working well,I think it may be a correlation...
The engine should keep running at idle speed after any throttle position even when cold, when properly controlled by the electronics. Research here for posts covering idle setting and control problems for detailed information.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 02-14-2022 at 08:03 PM. Reason: clarity |
My mechanic tested the voltage of the TPS, and it´s all right. He is guessing that the problem is the Ignition Control module 3.3L J716 22438AA050, or the Crank Position Sensor. What is your sugestion? |
It doesn't sound like a crank position sensor issue. They usually cause a no start scenario.
The iddle speed is around 500 rpm when it´s cold, sometimes it´s turn off.
There is a atrong smell of cathalytic converter when it´s cold. And the problem after full throttle, I leave the pedal and it turns off. So sad. Thank you guys. |
