Shaking
I'm having a problem that i'm not quite sure about:
Upon deceleration and close to the stopping point my car shakes very badly, but not quite as badly as during acceleration, which is very bad. All is normal after about 10MPH. Sound seems to be coming from under center console...hate to think of transmission problems since it was rebuilt 30,000 miles ago and has problem free since, but could this be related to a 1st gear problem in some way. any ideas? Thanks Caleb |
Check the easy stuff first
Before jumping to the transmission conclusion, have you checked the simpler and more obvious (and cheaper) possibilities?? Such as cross-member mounts, or engine mounts, which after 10-15 years could be in poor shape. How about looking at the brake rotors for warping, which can seem worse the slower you get when coming to a stop, causing things to vibrate.
Beyond that, something in the driveline may be starting to bind a bit, check your fluids to make sure everything is well lubricated, tranny, front and rear differentials, etc. Good luck, let us know what it turns out to be. |
Not rotors, just replaced, does seem like some sort of binding somewhere....
Have a look at the driveshaft. It can cause low speed vibration issues.
"Have a look at the driveshaft. It can cause low speed vibration issues."
Complicated? What to look for? |
engine mounts or transmission mounts? Pretty easy and cheap to fix?
