Need info on front engine seals..
Now that I've replaced the power steering lines on my car, I feel more comfortable in tearing it apart. I REALLY need to replace the timing belt and, according to a Subaru dealer, all the "front engine seals". I know the oil pump seal is included, and cam seals (I'm assuming 4 of them), but what other seals are they talking about?
While I'm in the front of the enigne, is there anything else I should change besides the seals and timing belt? Thanks in advance.. |
Depending upon the miles on your car, consider changing the crank seal, water pump, and idler/tensioner pulleys (or bearings). I had the seals and water pump replaced with the timing belt soon after buying the car and will probably do the pulleys the next time around. If you're over 120,000 miles, you might even want to replace the crankshaft pulley.
dcb |
To add to dcarrb, you'll want to do the lower cam seals too. The upper cam seals will not wear out. They are a plug seal that is not subject to wear. From what I've read on this board, the oil pump is pretty tough, and shouldn't need replacement. Definitely do the water pump while you're there. I just replaced the lower cam seals, crank shaft seal, waterpump, and T-belt. Its a fair bit of work, esp if you don't have all the proper tools on hand and have to figure it out as you go along.
Clarke |
It would be really nice if there were a list of parts with part numbers that should be replaced at when the timing belt is replaced. If there isn't one out there today, I'll try to assemble one once I'm done...
Try searching the network...I'm sure someone posted it.
Hey look at my thread called "more oil" dated on 1/31/2005. I was given the p/n's of all the gaskets and seals to be replaced. Don't forget the water pump gasket too. That thread should help you. |
Well I gave Subaru one arm and one leg......
I prepared a list of all the part numbers including quantities and descriptions and handed it to them and had the parts dept order all the items I needed before I brought the car in. I scheduled the car to have service one week later giving them plenty of time to get the items. Besides the seals and gaskets, I had them replace timing belt, water pump, oil pump, timing belt idlers, and thermostadt. They even wanted me to get the power steering pump replaced, but that's an expensive part and I didn't have any probs with it, so I kept my current one. I really needed to order the rear engine seal which I didn't do....I still have a small leak near the back of the engine and near the oil pan. |
I found this to be very helpful when doing timing belts:
http://endwrench.com/main.php?smPID=HTML::home.html Take a look in the archives for old issues. They did a whole article on timing belts along with several tips needed to complete the job. This is a publication from Subaru meant to help our techs and wholesale customers better service Subaru customers. Thanks, Jackie |
The front seals aren't too tough, but I thought the engine had to come out to do the rear crank seal?
KuoH Quote:
I am guessing that too, that's why I didn't have Subaru replace that.....It would have been a whole lot more than an arm and a leg
I really ought to get an estimate to get that seal replaced and also my oil pan gasket looks suspicious too, but how difficult is that to remove...it looks like the cross-member is in the way. |
