Towing manual trans SVX on tow dolly
The subject says it all.
I'm considering options for moving an SVX with a 5 speed manual transmission between cities. Normally I'd winch the car onto a car transporter trailer, but I can borrow a tow dolly for free. A tow dolly is basically a very short trailer, just a set of ramps sitting on top of a single axle with a drawbar on the front. It's intended to drive the car's front wheels onto the dolly and the rear wheels stay on the ground. Then the dolly is hooked up to the tow vehicle just like a trailer. Obviously with a 4WD automatic this would probably spell death to the transmission in the car being towed, but what about an SVX with a manual gearbox ? I think that it would be perfectly ok. But before I destroy a transmission, I'd be keen on other opinions. Thanks |
Re: Towing manual trans SVX on tow dolly
Remove 4 bolts, disconnect the driveshaft at the rear end, and grab the driveshaft with a bungee cord or ratchet strap to hold it up so it doesn't drag on the ground.
You can drive it on the dolly first, then do this, so you don't even need a jack.
even with the manual in neutral and leaving the DS connected, would anything happen?
if the drive shaft it out, no issues. leave the back wheels down on the road.
4 bolts to take the shaft loose at the rear diff, but you could loose gearbox oil up front without shaft (depends ) so take a hog pan to let it drain into with it out before you take off. you cannot leave the driveshaft connected and dolly a car on the ground, the center diff will burn up.
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K Last edited by bheinen74; 03-18-2015 at 09:31 PM. |
The previous posts about removing the drive line to the rear and wire it up is fully correct. Automatic or manual is not the case here, its the lack of neutral for the center differential (transfer case) is where the problem lies. Make sure you don't drop out the drive shaft or you will loose transmission fluid from tail shaft.
-- Chris Founder/Administrator SVX World Network ECU Tune (stage 1), PWR (prototype aluminum radiator) Amateur Radio - General Class - K7SVX #1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed) #2 92 Teal LSl 125k (Retired, car rescued from a field of weeds) 2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver) 2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler) 1985 Honda VF500 Interceptor (fair weather fun commuter) Going on 11 years of NHRA bracket racing NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com) 2000 1st Place Club Challenge Series 2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway) 2003 4th Place Season Track Champion, Import Racing (Firebird Raceway) 2003 1st Place NW Regional Import Shootout (July 5th) 2004 1st Place Club Challenge #1 (Firebird Raceway) 2004 1st Place NHRA "King of the Track" race 2004 NHRA Gold Cup 2nd place season win 2004 Import/Sport Compact 3rd place season win 2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC) 2007 1st Place Import Survival #3 2007 1st Place Track Champion Import Summer Jam (Wild Street Class) 2007 1st Place Import Survival #5 2008 Club season 1st place win, Club Champion 2008 2nd Place Season Import Final. 2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or) 2009 2nd Place Import Summer Jam (Wild Street Class) 2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2 |
Yes, you'll burn up the viscous center diff.
