URGENT: Wheel Studs Question
Ok folks. Just my luck one of my wheel studs sheered off at some point and I noticed today. I need to get it replaced before this Friday cause I'm going to the Track.
Here is what I need to know: Part # for the Stud and Lug Nut. More importantly, do any of the other scoobies share the same wheel studs or does anyone know if Autozone/Pep Boys carries the studs. Thanks in advance. -mike |
Well the lugnut is 28181PA001 and is $7. Im sure you cant get that at autozone etc.
Mike |
Yeah I'm more worried about the stud.
-mike |
wheel stud
I would use oem first but Bendix is good brand that big o tires uses along with countless others. victor
Just an FYI in case someone does a search in the future and needs the info...
SVX Lug Nut (Proprietary to SVX): PN: 28181PA001 Wheel Stud (RS/SVX/Legacy/others): PN: 28055AA002 Hope this helps someone when doing a search. Key word search: Wheel Stud Lug Nut -mike |
Just a followup on this.
To do the wheel studs in the front, you need to remove the rotor, and then use a hex-key to loosen the ABS ring so that you can insert the studs from the rear. This had us perplexed for about 5 minutes last night while doing this job. -mike |
I can swap 3 wheels between 2 SVXes in 5 minutes (including lifting them up on the tiny jacks. Can I be counted as the wheel stud?
L
