KeylessRide replacement remote
Had my factory keyless entry remote stop working in my 92 the other week even after replacing the battery. So after searching the forums for a factory replacement I found keylessride.com. They currently have 2 replacement choices for our SVX: a similar square FOB w/2 buttons and a round FOB w/2 buttons. I choose the round remote and the total for me was $45 shipped. Its similar in weight and a slightly thinner profile. It comes with programming directions specifically for the SVX, has a red indicator light, and both buttons do the same function after programming them to the SVX. Pic below shows the size reference.
So far it functions the same as the old remote. No added range unfortunately. Worth purchase in my opinion. |
Re: KeylessRide replacement remote
I have several of the rectangular ones and they work great. If you want extra range, point the fob at your chin and it will add range. Try it, it works.
Doesn't that only work if you have a steel plate in your head or shrapnel?
It isn't required, but it helps.
[SIGPIC][/SIGPIC]Kenyatta The farther backward you can look, the farther forward you are likely to see. -Winston Churchill My baby: 94 lsi My fast baby: 2001 Suzuki Marauder My new baby: 2010 Subaru Outback |
Programing instructions in the How-to documents HERE They are the same for the OEM and keylessride remotes. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 09-06-2013 at 07:33 PM. |
Got it. Thanks for the info, now it seems my security system is stuck on on and will not go off when the switch is pushed. When/if I get that problem solved I will have what I need to program the remote.
Thanks again Kenyatta
Usually a steady ON red LED is a sign of a security module which has died.
I know i should not be piggy backing off some else thread, but I don't have a remote for my 92. Is there anyway for getting a FOB that works and can be programmed?
ALL WAYS JUDO CHOPIN' "Wait...your grill...is that chicken wire?" |
