Old 07-24-2014, 03:09 PM
Coan's Avatar
Coan Coan is offline
Alleged User
Power Antenna Woes
The power antenna motor in my '97 quit working last fall. I recently picked up a '95 parts car with a working power antenna. Last night I pulled out the working antenna/motor assembly from the parts car, and without removing the old one I plugged the new one into my '97 and laid it on the trunk to test. It does not work either (in my '97). Works just fine in the '95 though.
Clearly there must be an issue with getting power/signal to the antenna. I checked the motor connector with a multimeter and it seems that one of the 3 pins is getting 12v when the radio is on. Has anybody else encountered this issue before? Could the problem be something inside the stock radio not transmitting the power? My stereo system is 100% stock, complete with buzzy, blown speakers.
I searched, but every thread I found ends with the motor being the problem. Can't seem to find anyone with this issue.
Jon
1997 SVX LSi Bordeaux Pearl
1995 SVX L AWD Polo Green - 277k miles
1986 Pontiac Fiero 3.4L Twin Dual Cam V6
Old 07-24-2014, 03:40 PM
Coan's Avatar
Alleged User
Re: Power Antenna Woes
Of course, now that I created a thread I just found this post
Originally Posted by SVXdc View Post
The connector for the antenna motor has three wires:
  • Black = ground
  • White = +12V constant (from fuse #22)
  • Black/Green = control from radio
The latter gets +12V to raise the antenna, or open-circuit to let it retract.
I already checked all the fuses under the hood and none are blown. Now that I know each pins function, I guess I better recheck each pin on the motor connector to see which one is not doing it's job.
Jon
Old 07-25-2014, 05:18 AM
Do you have the stock radio in the car?
Old 07-25-2014, 05:38 AM
Yes. (see first post).
Old 07-25-2014, 05:53 AM
Have you tried swapping the radio from the parts car?
Old 07-25-2014, 09:12 AM
Coan's Avatar
Alleged User
I have not because it's in very poor shape. I do have a 2003 WRX 6 disc changer sitting on the shelf though, it may be time to finally order that wiring harness that I need for it.
Jon
