steering wheel
Is there a way to center the steering wheel? Mine is a little off, and it bothers me. I had my wheels balanced, air checked and had a wheel alignment. The steering wheel is still off center. Any ideas?
Dan,
The alignment shop should have been able to center the wheel and make the alignment adjustments underneath to compensate. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
What he said!
![]() The steering wheel is centered with the rack. You don't want to change that. It can only be fixed properly by another alignment.
I can do it without an alignment machine.
![]() The problem is whether or not the person doing the alignment has the total toe set correctly or if it is just a tweak off-center. If the total toe is correct one could just loosen one tie rod jam nut, turn the tie rod while counting the jam nut flats, tightening the nut and then adjusting the opposite side the same number of flats. (adjust the tires to the side the wheel is turned towards) To be fair, sometimes no matter what you do during an alignment the wheel will come out a hair off. I've done too many to waste time re-mounting the alignment heads, etc. to just tweak the wheel to center. Hopefully your alignment tech can fix you up in a few minutes.
