replacement of modified strut mounts
My 94 has developed a knocking noise from the front drivers side suspension when going over bumps. After 200,000 miles, not a bad problem. Checking with the service bulletins on the forum, the TSB states that the problem can be solved by installing "modified strut mounts". Are these the same as "top hats"? Are there parts available from Group N or aftermarket that will fit the SVX? What are the "modified strut mounts" from Subaru compared to aftermarket, Group N, if these exist?
Re: replacement of modified strut mounts
okay since no one has replied, I searched Google and asked the question; yes they are the same. I checked a couple of strut manufacturers and almost all Subaru models use the same part # strut mount but I couldn't find a listing of a strut mount/tophat for our SVX. The question still remains if Group N mounts will fit the SVX?
search for imprezza/wrx suspension swap there should be something in that thread about it read through this thread http://www.subaru-svx.net/forum/show...ght=suspension Last edited by aust92pearl; 12-17-2011 at 09:18 PM. |
The only strut mounts made to fit thr Svx are the regular oem ones.
I'm willing to try to drill a couple of hole if the Group N mount will fit but I've never tried to modify the suspension. Is the upper mount/top hat, assessable from the top of the strut tower or does it need to be installed from the underside. I did have Koni's installed in the front/rear; does this make any difference in the selection of the top hat?
bump. Can't anyone give me an answer?
