PS pump or something else (or more?)
On my way home last night I had a bunch of lights pop up on the dash. They were the battery, stop light, the brake light, and the ABS light. I'm a bit confused as to what this could be. No engine light and the braking seems completely fine. The PS is non existent right now which I noticed when I had to take my first turn after that long straight where the lights came on. I have since driven the car twice with the same results. Of course, my car is a 95 and I'm not witty enough to jump the pins being that noone has an OBDI scanner in the area.
HELP!!! Is is just the PS pump and did it really cause all these other lights to come on? Thanks in advance guys. |
Re: PS pump or something else (or more?)
PS pump somethingelse (has more!)
somethingelse and more.
do you see 2 belts when you pop the hood? any noises come with these problems?
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
The rad patch won't hold, so start planning. I tried on mine 3 times. I bought one last year for $130.00 on Ebay, works great so far.
If your crack on the radiator is not too large, you can use Alumaseal, i tried it on both my Kawasaki KLR bike and my 1972 Chevrolet Chevy (Nova in USA) and the thing worked amazingly well, i couldŽnt believe this product actually worked, because another product that i tried in my Accord, (some kind of powder like tiny metal bits) actually clogged the system and caused a big overheating, but i gave this product a try because it was my only hope, a new rad for my bike was far too expensive!
It worked after a few hours of running the engine (it took longer to seal the Chevy radiator because the leak was HUGE!. Two days in this case) And is safe for aluminum radiators as the one in the Kawa is made of it. There are two kinds of products they make, but i used the liquid one in both cases, being this a permanent repair, as i am using the Chevy as my daily driver and no more leaks in 6 months. PS: OMG! I fogot to add the Chevy in my signature
95Ž Subaru SVX EURO 85' Mercedes 190 2.3-16 86' Mercedes 190E 70' Olds Toronado 98' Renault Chamade 82' Honda Prelude 79' Honda Accord awaiting restomod. 69' Mustang Hardtop 67' Jeep Ford Willys awaiting restoration. 67' IKA Torino Coupe 74' Renault Torino Coupe Last edited by MadMaxSvx; 09-10-2009 at 04:59 PM. |
From my experience, when I used it in desperation in my SVX, it took ten minutes before it seized my waterpump, severely overheated my engine, and shredded my timing belt. The heat from the timing belt also cooked some of the timing pulleys, resulting in the dust seals popping off (one of which caught in the new belt later on, making me skip timing and having to redo the belt for the third time). So from my own experience, cooling system sealant has worked before on my toyota trucks, BUT I wouldnt use it in the SVX, it does not like it. The best fix is replace the radiator with a used or new one to save yourself a lot of trouble. |
