VIN info required
Hi there,
yesterday Ewie & I helped another fellow SVXer (Gol) rescue another SVX from being crushed. It is a 1992 model with license plate number SK6003 (deregistered after being in a crash) It is a grey metallic with no sunroof, leather trim around the seat edges & similar armrest material on seat inserts - solid one piece fold-down rear seat. Visors are written in Japanese only - with Alycone on the rear light. Vented discs in all 4 corners. SO WE ALL ASSUME FULL JAPANESE IMPORT - all switches are in english?. One headlight is plastic & one is glass - neither have the fog/driving lights fitted, although this switch function is inside?. It does have power fold out heated side mirrors. Funny thing is that is has no NZ VIN number anywhere ???? it has been sitting around for approx 4 years (outside) - normally NZ VIN would be mounted on the driverside strut tower - opposite side to manufacturers plate. I only have service manuals for USA & the VIN ID chart does not help me.. This is the info from strut tower plate inside the engine area - (Japanese writing only here) = E-CXW VIN = CXW-002711 (same number also on the firewall) Applied Model = CXWA23E Option Code = BXC Trim Code = 220 Engine Type = EG33DDX1DE Color Code = 222 (grey metallic) Transmission Type = TZ102YL1AA Any info would be great. Thanks
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 01-01-2015 at 10:43 AM. |
Re: VIN info required
It sounds like it may have been imported to NZ after 2000 which means it would not meet the required frontal impact standards and therefore could not be registered.
The chassis number doesn't appear on my list of SVXs in New Zealand.
paddlesnz 1993 Subaru Alcyone SVX 1980 Isuzu 117 Coupe Giugiaro Edition 1999 Mazda Astina 2006 Honda Legend 2006 Toyota Mark X Premium 2007 Toyota bB 2007 Mazda Roadster RS 2012 Peugeot 208 Allure |
The car has had a WOF (about 4 years ago) plus registered around same time.....can they force car off road because of law change ?
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Mmmm, that throws my theory out of the window. Do you know the plate number?
Not sure exactly when the 17 digit VIN plates were introduced for used imports but it was around 1992 so it is possible it may have been imported before the new VIN plates were required?
We did a CARFAX check while waiting around for the tow wagon - could not get any info on the plate number....see first posting update for plate number
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 12-31-2014 at 10:47 PM. |
