Transmission noise
I was heading to work in the morning with my 95 awd automatic with 220k and when I accelerated from a stop I heard a clunking sound. At first it sounded like something could have been loose like an axle popping out and not engaging. I took it home and checked out it later. When I drive at a very slow speed regardless of drive or reverse it will move and then feels almost like the Park is trying to re-engage. If I drift really slow it will move forward, then make the clunk and stop for a split second, then go again and will do it all over again. I'm not sure exactly what the problem is and any help is appreciated.
06 Ford F150 Crew 4x4 142K+ miles 05 Volvo XC90 163K+ miles 02 Toyota Camry 170k+ miles |
Re: Transmission noise
If that happened to me, my first guess would be the front differential has tanked.
dcb |
Yep, front diff. Drain the oil and look for a nice lil tooth stuck to the drain plug
I've heard of axles popping out, For me it was a front diff tho GL
Thank you for the replies, I am assuming it is the front differential. I will examine it at some point in the future when I have time to do so.
Why so many diff failures on SVX, diff gears are some of the most hardy parts of any car or should be, never had one fail, just curious. Good day all ..........G
I thimk ther4 I an, what? huh! 03 Baja. 05 Baja turbo 92legacywagon"snow" 94legacywagon"whinny" 84Brat"huey" 92svx"samantha".pearl 92svx"sabastian"4.44 silver 92svx"sabrina".ebony 05legacy gt limited "Moon" blue. 06 Subaru legacy gt limited. |
