Closed Thread
Old 06-15-2012, 07:27 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
finally done with svx's my black 92 touring is up for grabs
we are purchasing a brand new car in the next few weeks and i am offering my black 92 svx for sale to the forum guys first
Location of the SVX: east orlando fl
Year:1992
Model:svx lsl touring
VIN: jm1cfx359h106412
Manufacture date: 1992
Paint Color:black on black
Interior Color: grey
Miles: 86,000
Options: fully loaded power everything
AWD or FWD: AWD
Modifications:
Cross drilled slotted rotors 200.00
HID headlights 150.00
Small car center grill 200.00
Upgraded front and rear speaker with Mb Quarts 400.00
Upgraded 5 channel amplifier 200.00
Upgraded bazooka bass tube 200.00
Upgraded brand new alpine head unit 300.00
Cold air intake system k/n 100.00
Brand new header back magna flow exhaust system “all mandrel bent “ 600.00
White indigo gauges
Black carbon wrapped hood/mirrors
Upgraded trans cooler
$2,300 in aftermarket parts alone !
Major service:
Engine maintenance and work done
New front tie rod ends and alignment 250.00
2 spanking brand new wheels bearings with proper bearing grease 600.00
New a/c system upgraded a/c system, new compressor/fans/condenser/ with new 134
Timing belt and water pump done by previous owner
New valve cover gaskets and cams seals, covers as dry as can be ! done by previous owner
New pvc valve
Brand new battery from AutoZone 80.00
Engine Condition: very strong
Maintenance Records: some available
Transmission condition: transmission has the occasional shift flairs from 2nd to 3rd it has not got any better but has not got any worst car is still perfectly drivable and only does it once in a blue moon, the previous owner sad the transmission was replaced
Glass condition: perfect, no scratches
Type of tire and remaining tread: lots of tread life I would estimate 75%
Type of wheels: OEM factory
Interior condition: very good shape some wear on driver’s seat typical for the this age of car
Body condition:
Known defects or problems:
Transmission as described above
Steering rack inner tie rode is worn out has small play in the driver side wheel but has been this way for a while now, the mechanic said it needs to be replaced and has a small power steering rack leak but its nothing major only a few drops here and there my garage floor is clean
Drivers side corner panel has a dent but has been repaired but not very well from the previous owner you cant tell in the pics but it is noticeable up close
The speedometer sometimes doesn’t work when the prevouis owner replaced the gauges with white gauges there must be a loose connection some where a swift tap on the dash and they start working,
Comments about the car: this is a great car with low miles and tasteful mods,
Car still has lots of life in it and would be great for any collector
Asking price: make offers
I paid $4,500.00 for the car back in November I still have the receipt
I put in the new tie rod ends and alignment at $250.0
2 new rear wheel bearings $600.00
New battery with warranty 60.00
New pcv valve 10.00
Completely re-did a botched exhaust system with a nice mandrell bent magna flow system 600.00
I have all the receipts if you would like a copy I have a total of $6,000 into this car with all receipts to provide
I would consider a lower price without the killer sound system also, previous owner has about a $1,000.00 worth of audio gear in it, the svx it sounds awesome !
car has always been garaged its entire life ! the paint is amazing not a single fade mark anywhere !
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 06-15-2012, 07:33 AM
Re: finally done with svx's my black 92 touring is up for grabs
guy i will have pics taken this weekend i am having it profesionaly detailed and shampoo'd
this is the only pics i have for now
http://i1212.photobucket.com/albums/...7/IMG_4386.jpg
http://i791.photobucket.com/albums/y...X/CIMG0018.jpg
fog lights no longer there
Old 06-15-2012, 09:25 AM
Your VIN appears to be incorrect and has only 16 numbers
JFICX3538NH106412
Old 06-15-2012, 09:33 AM
jf1cx359nh106412 sorry forgot the N
Old 06-15-2012, 11:50 AM
Wow after all,u went through through to get one I thought you would have hung on to it a little longer. NICE clean car, good luck with the sale.
Old 06-15-2012, 12:01 PM
thanks conn, this one is the last one i will ever own =< the age and maintnence on these cars are geting up there, no fault to there own we all get old some time => it is and always be one of my favorite cars,
i will have nice pics for every one on monday ,
Old 06-16-2012, 03:21 PM
here are the pics just finished having it detailed
i have more if you like
this one shows where the repair was done
Closed Thread
