Fast turn signal, bulbs working
My right side turn signal flashes faster than it should, as if a bulb was out, but both bulbs are working. Any ideas
Re: Fast turn signal, bulbs working
One of the bulbs provides a resistance greater than what the car is expecting. I would try swapping the bulbs from the other side of the car to see if that stops it - then you'll know which one is the culprit.
Just a thought... Keith |
Tom |
Yeah, I already replaced the front b/c I say it was dual filament and thought that even though it was flashing maybe the other filament was burnt and should be blinking also.
I have the bulb to replace the one in the rear, so I'll have to do that when I get it back from the body shop in a couple days. We only have one flashing bulb in the rear, correct? |
