06-07 WRX/Imprezza 5spd?
Hello guys,
In the course of ALOT of research, I'm finding some interesting info pertaining to WRX's. Mainly that not ANY WRX tranny can be bolted up to our rear end. Specifically, the late 04's-05's have a different type of front output from the front diff - a female output, requiring the male version of the CV axle to be at the side of the front diff. But it's my understand that this can be overcome mearly by using WRX front axles. A little more interesting is the 06-07 WRX/Imprezza transmissions... they use a different final drive ratio, so you have to swap the rear end over just like the older imprezza/Legacy/outback's. On top of that, they have the funky type of CV axle that the late 04's - 05's have. I've got a question... anyone put any of these transmissions in thier SVX? Did you use the WRX axles to a successful result? And the big question - can an 06-07 tranny be used in the SVX by using the front and rear axles, and bolting the rear end up? I think it's silly to put all this money into a transmission with low miles, just to have it go through my 130k miles SVX rear end which is likely to fail. -Craig
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
Re: 06-07 WRX/Imprezza 5spd?
The newer transmissions only require you replace the axle seals with ones from the SVX auto. Then slide the axle stubs from the auto into the 5mt and tap them in with a soft faced mallot. Bam, wrx trans ready for the SVX
The rear is the same swap we have always done. Use the case and gears from the donor car and just use the SVX carrier and side plates. If you want to be a bugger, change the carrier bearings. No axles work from a newer imprezza except the STi rear axles, and they only work with an R180 Tom |
Thanks for the info Tom.
I am really trying to find a way to replace the rear end, to kind of "update" everything I can. But if not, I'll probably just stick with the SVX rear the way it is - I definitely don't want to go into that case and mess something up. Also, will your cross-member fit an 06-07 tranny? Quote:
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap Last edited by ridered777; 07-21-2009 at 05:20 PM. |
if u want new axel stubs + c-clips for the tranny when u install it, I have the part numbers for them!
Axle Stub Part Number: 38415AA110 Circlip Part Number: 805329010 u need two of each! enjoy!
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill. 1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback |
Tom |
I opted for an 05 transmission, I hear bad things abouts the 06's ratio... Didn't they only keep the 3.70 for a bit and switch back?
Also, you can get axles at Autozone or its equivelent for 60 bucks with a life time warrenty, do this instead of givin Subaru 300 dollars for them. Last edited by STeeL25T; 07-22-2009 at 06:22 AM. |
I have good SVX axles, I don't see where you're goin with that. And I'd get axles from Robbins if you have one near by, much better buisness and personnel than AutoZone. Also, anyone know any info about the compatablity of the "components" with the 07 impreza to an 02-03 tranny? I have a post on NASIOC here: http://forums.nasioc.com/forums/show....php?t=1809191 But no one is responding. Silly me for asking a non-boost related question on NASTICOC and thinking I'd get an answer... :rollseyes: Summary of the post is that I found a donor 07 with most of the parts I need for really cheap, and it only has 8k miles on it! But, I can't use the 07 tranny obviously. So does anyone know if components like the pedals, clutch master, brake master, brake booster, shift linkage, etc. will work with an 02-03? I would GUESS not since they have a different clutch type (The switched from pull type to push type in 06 I think), I figured it was worth looking into.
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap Last edited by ridered777; 07-22-2009 at 10:47 AM. |
