additive
Do you have to put that limited slip additive to the rear diff. I didnt on mine. To tell you the truth i couldnt get the fill plug off so i filled it from the drain plug and got a quart in there. i really dont want to do it again but if i have to i will.
94 Subaru SVX FWD 51k ![]() 04 Mazda B4000 (work truck) |
Re: additive
No additive needed,and I would say if you "filled"
Re: additive
well, i added a quart to it and i had the drain plug in my hand so there is at least a quart in there. so if anything there is too much in there. idk how else to get it off. subaru wasnt thinking when they made steel bolts and a aluminum casing on that. and i didnt want to put heat on it. that kinda scares me
Re: additive
Factory Service Manual says to remove the Fill plug and add oil until it is at the mouth of the fill hole. The total capacity is 0.8 quarts of diff oil.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Re: additive
then i should be good then. i put valvoline dura 80w 90 in it. The reason why i asked cause my truck has a limited slip and i called mazda about it and they said they always add a bottle of additive to there limited slip diffs.
Re: additive
I can't figure out how you took off the bottom (drain) plug and addded a quart to it...
![]() Thats the same as saying you could never drain your rear differential (which only holds about a quart. taking off the drain plug would mean nothing would come out. ![]() The fill capacity is measured at the bottom of the top plug. .
