4-EAT "Quck Change Module"
One of these appeared on TradeMe (NZ version of eBay)
http://www.trademe.co.nz/motors/car-...-449726039.htm Anyone know if they actually do anything?? |
Re: 4-EAT "Quck Change Module"
I have had one installed on my car for over 15K miles, on a good transmission. Definitely has improved shifting, especially under harder acceleration. Inexpensive and easy to install. There are other good options available but, will cost double or more.
Gene
I did not like the way the box was controlled by the TCU, it promoted a lot of slipping of the clutch/band engagement, as they tried to make the box silky smooth, and it is has been very sucessfull. There are about 150 working in SVXs all around the world. Cheers Harvey.
Thanks Harvey, I pm'd you before reading your reply here. SURTEES is based here in Auckland and has one fitted to his car. I'll have a chat and see what he has to say.
Ewie,
after buying directly from Australia & fitting it after a few weeks (and talking to others in both AUS & USA) they had all told me to NOT FIT IT - if the auto was working correctly!!! These things (quote from supplier in AUS) are only to aid with slipping belt type syndrome - firms up the changes by supplying higher than normal working voltage to gearbox TCU (fools the TCU). If gearbox is working ok (as is my case) then they can potentially do more damage than good!!. Hence will still keep mine for when I need it!! Last edited by SURTEESS; 02-19-2012 at 12:20 PM. |
Don't know much... actually anything... about transmissions, but a slipping belt syndrome sounds to me like damage... damage that the "Quick change module" was designed to prevent, has already happened. Put it on after the fact? Sorry, but wouldn't that be sort of like closing the gate after the cattle get out. Keith |
I bought mine from Oab_au about 4 years ago, about the time that there were a lot of doggy "dropping resistors" being sort on Ebay to fix transistor slipping issues with the gearbox - check on the following for various outcomes -
http://svxworldforums.com/forum35/ |
