Transmission ID
how do you tell what transmission I have, I got one from a yard a while back and Im not sure if its 2wd or 4wd, and second does it matter if its 2 or 4wd, can you put a 4wd trans in a 2wd car? I only ask because I am in the process of buying a 94 2wd with a bad trans, and I have a trans in the garage, thanks Johnny
Re: Transmission ID
first get the number of the top of the trans I can tell you what it is.like this TZ1022M1AA. second 4 wheel drive has a output shaft out the end. next lot of work to convert to 4 wheels drive. also the 2 wheel drive are 3.70 gears.
Re: Transmission ID
They're are not very many 2WD Subaru transmissions around. For many years almost all Subarus have been 4WD.
1997 Bordeaux Pearl, 2006 Alfa Romeo Brera 3.2 6MT, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V, |
Re: Transmission ID
so the one I have in the garage on a stand is TZ102ZM2AA- KR, I see the output shaft on this one , so I would tend to believe it is 4 wheel drive, do you think its possible the one Im trying to buy 1994, is 4 wheel drive but the owner doesnt know its 4 wheel drive, as I know on my 92 there is a fuse to pull to make it 2 wheel drive. if by chance the 94 is 2 wheel drive , would my 4 wheel drive trans work in it?
Re: Transmission ID
You're doing a lot of wishful thinking.
Your transmission will have 3 outputs if it is 4wd. Left and right for the front wheels and rear for the back wheels. The '94 is likely a 2wd if he says so. It takes 10 seconds to look under it and see if there are CV axles going to the front wheels and a driveshaft to the rear differential. 2wd is front wheels only. A 4wd transmission can only be used on a 4wd car and a 2wd transmission can only be used on a 2wd car. Personally I wouldn't buy a 2wd SVX for any price, especially with a blown transmission.
1997 Bordeaux Pearl, 2006 Alfa Romeo Brera 3.2 6MT, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V, Last edited by Blacky; 02-20-2022 at 07:05 AM. |
Re: Transmission ID
If I could get him to send me the VIN, could I go to the subaru dealer and have them run a check on the car to see what it was born with?
