4EAT failure?
'96 LSi, no mods, owned since 24 September 2010.
Problem: 4EAT not shifting right; won't "kick down" properly Symptoms: 4EAT revs SUPER high (4500-5500) for extended periods when just trying to mildly accelerate from cruising speed (i.e., in 4th gear going 45mph and normally accelerating up to 55mph). Checked/tested: Haven't checked too much - I don't own an OBD II tool, I'm not the handiest or most knowledgeable guy under the hood. • I've tried shifting manually to see if that helps - no help • I've tried pushing in the "manual" button to see if it will "kick in" to the proper gear - no help • I've checked the ATF level - I THINK it's okay, but I can't tell as the dipstick just comes up with a smear of fluid covering the whole range of marks, no matter how I wipe and reinsert it. ![]() • ATF is a nice light pink - not burned, doesn't smell odd • no CEL Now, one CRUCIAL thing is that I DID have a hose going to the tranny cooler that was leaking (hose clamp wasn't tight), but I have another bad (but completely unrelated) leak leaving a puddle in the same spot on my driveway, so I didn't realize the tranny was leaking. It's possible that I still need more fluid, but I can't tell because the dipstick isn't clearly indicating anything (see above). I added two quarts after tightening the hose clamp (at that time the dipstick was basically DRY ![]() It's also possible I may have over-filled the thing (again see dipstick reading problem). I read this "elsewhere on the internet": Quote:
Austin __________ '97 LSi Ebony - daily driver - mostly just needs body work [couple o' rust holes, door dings, and peeling clear (of course)] '96 LSi, Laguna Blue (retired - soon going to a new home) '89 XT6 5 speed (Gone but not forgotten) |
Re: 4EAT failure?
Are you checking the dipstick with the engine running? Is the fluid warm or cold? If cold, did you cycle through all of the gears before checking the level?
The best trick I have found is to rmove the stick, wipe clean, insert stick, pull stick out far enough to be able to rotate it, rotate 180 degrees, insert fully again, pull out and read. It really is a PITA though! Good luck!
Re: 4EAT failure?
Re: 4EAT failure?
The dipstick has to be fully seated to check the level. Unless you can measure the distance difference when you push it to the Oring and then compensate...
Next time, when you first pull the dipstick to wipe it clean, apply the fluid that you wipe off to the Oring and the top of the dipstick where it goes into the tube.
Re: 4EAT failure?
I'm checking the tranny fluid about half an hour of driving it for a while. My reason for this is I know not to check it cold, but when it's "fresh hot" I'm guessing there's a substantial amount of ATF still in the filler tube and running down the dipstick. If I wait a half an hour I figure most of the ATF has slipped down the walls of the filler tube, but the fluid's still at "hot" levels within the tranny.
Sean, in my case, I'm able to get the dipstick fully seated with no problems at all, it's a snug fit when seated, but not hard to pull out... pretty much as one would expect a "normal" such item to fit/seat. My process of shifting is basically, "put it in Drive and don't mess with it", but when I'm shifting manually, on the odd occasion that I'm testing or whatever, I go 1, 2, 3, 4 (with the "Manual" mode/button engaged). Otherwise I basically drive it as one would normally drive an automatic. That being said, however,... ...for almost as long as I've owned it the car has had this really annoying habit of surging a couple of hundred RPM once I've hit 4th gear. Even using cruise control here in FL on our flat highways - well, flat EVERYTHING. ![]() EDIT: Also, I have the car in FWD mode because I began experiencing some thumping noises in my rear diff. Putting it in FWD totally "fixed" that. I've been driving it that way for many months now, no issues as near as I can tell from that but I thought I'd mention it. EDIT #2: I totally misread the question about the cycling of gears - I thought it was a question about how I shifted when driving manually. Now I see that it was a question about how to cycle through the gears to check the ATF level when the tranny's cold. Dopey me! ![]()
Austin __________ '97 LSi Ebony - daily driver - mostly just needs body work [couple o' rust holes, door dings, and peeling clear (of course)] '96 LSi, Laguna Blue (retired - soon going to a new home) '89 XT6 5 speed (Gone but not forgotten) Last edited by Austin; 03-05-2012 at 11:20 AM. |
Re: 4EAT failure?
Austin, is it running when you check it?
Re: 4EAT failure?
Re: 4EAT failure?
Thanks - I might consider it at some point. Right now, I think I'm evaluating whether or not to even keep the car. It's been a bit of a pain. As much as I love the SVX in general, and I've wanted one since 1990 when I saw the concept car in Popular Mechanics. I even almost bought one new in '98 (an unsold mica black LSi).
Unfortunately, as much as I love the SVX, I think I might be better off with a second XT6. ![]() This isn't just a rant or an emotional response to my current problem, it's a rational evaluation of where I stand economically and practically with this vehicle. My XT6 is far less problematic and much easier to work on when I DO have issues. Don't get me wrong - I really really really wish I could keep the SVX, but right now the financial future looks pretty bleak with this thing. It has a couple of other major problems that I need to get fixed rather just living with them... one of which is a brake line leak that causes me to go through about a pint of brake fluid a week (even driving it touching the brakes as absolutely little as possible, e.g., sitting in neutral at stoplights with my foot off the brake, etc.). Sorry - got off topic there.
