Does Royal Purple smell like burning rubber when its bad?
I am certain this is going to come across as a stupid question but i'm in unfamiliar territory here.
Lately I've had an awful 'burned rubber' smell coming from my car. I can smell it both inside the car and outside and when I go home it makes the entire garage smell like it. I just had the AC filled up and I found that the AC belt wasn't tight so it was slipping and I thought that was where the smell emanated from. I tightened the belt (this was a month or two back) but i'm still getting that smell when i drive the car. Yesterday I was looking all over for what it could be and decided to check the oil level of my supercharger (Lysolm twin screw) and it was about half full and when I took the filler screw out the burned rubber smell got worse. It is filled with Royal purple so is it possible that is what is burning? I can't seem to find anything else that might be causing it. Any thoughts?
'93 LS-L named "Samantha Victoria Xavier"...Sam for short. All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter. |
Re: Does Royal Purple smell like burning rubber when its bad?
I've never used Royal Purple but oil is oil and hot oil smells like hot oil. If you smell hot rubber, keep looking for hot rubber.
I had a loose alternator belt on my STi, tightened it, and it kept slipping anyway because the earlier slipping had ruined it.
1995 Caterham 7 Twincam 2002 Porsche 911 targa -- now with FSI 4.0L power! 2007 BMW 328i Cabriolet 2012 Tacoma 4wd v6 Access Cab 2013 Mercedes E350 4Matic Wagon 2005 STi - totaled after 10 great years 1994 SVX LSi 5spd - sold but not forgotten 2000 Legacy GT 5spd sedan - gone after 150K miles of bliss |
I had that thought as well and I still haven't ruled it out. I have driven it some and rechecked the AC belt and it doesn't appear to be slipping but that doesn't mean that its not while the car is driving so I may replace that again anyway.
I just thought it was odd that the smell had mostly dissipated until I took the filler screw out of the supercharger. Once I took that off, the smell got real strong again, which is when I became concerned.
oils with tons of additives smell really odd when they get burned. when I put bg moa in cars that burn oil they smell like transmission fluid is burning. I would just change the oil, a supercharger cant hold that much.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
Yeah, that is what Nate suggested too. So this weekend I'll go get something to siphon it out with and put a new bottle of royal purple in.
I'll let you know how it goes ![]()
