engine dieing
Hi just logged on for first time had an Xt6 got rid of it and got legacy got rid of it etc anyway bought an svx 1993 ann. edition and started driving it ran great for about 3 months since then has devoleped a nasty habit of dying sometines in park or while driving can most of the time be restarted but not always Will ALWAYS crank though simetimes starts to only die again can most of time be fixed by turning completely off and restarting it can anyone help me with this problem it is annoying and dangerous
do you have a check engine light on
engine dying
Has similar problem. Neede 3 towings. it was the fuel pump. "check engine light" will not come on. suggest change fuel pump.
check engine light does stay on for approx 5-10sec after dieing SOMETIMES otherwise it starts but as soon as accelerator is pushed it dies again it will normally do it mostly on the top half of gas tank does that matter? I am thankful for all the help I have receved. x? what is pump the approx cost for fuel pump
and what kind is good other than OEM? walboro? |
you can pull out the back seat and check the connector of fuel pump. But I doubt its the fuel pump, usually they dont go bad unless you have water or always running almost empty all the time.
Keep us posted. PS... I am parting out one of my SVX and I am not too far away from you.
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD 92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD 92 Teal SVX LSL lowered with Konig. SOLD 92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone 94 Red SVX L FWDwith LSL Leather Interior. SOLD 92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD 95 Polo Green........With Trany Problem. GONE Almost complete Rear Wheel Bearings Job with Pictures in my locker My Locker http://www.subaru-svx.net/photos/user.php?pearlm30 |
Sorry about the hijak
I have the same sort of problems, and i was wondering if you could post a pic of the fuel pump connector and how we're supposed to know if it's bad.
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit. Next changes ... PAINT, fix engine problems, 4.44. (GONE) '97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE) |
Did you check the codes? Could be either a Vacuum leak or the fuel pump.
parts and connections
hi me again I was wondering if the gentleman that was offering parts wold be interested in selling the belt cover off his svx i am missing mine also I have checked the fuel pump connector and it is solidly on how much pressure should the fuel line have I see aftermarket pumps offering 200 + should it be that high?
I love this car and am trying to make run like new it has 119000 mile on it tranny was rebuilt by subaru @ 94000 miles 2 years ago it has been fluid changed and running fine. on the dieing could the throttle body be gummed up and cause this problem as subaru has never serviced this car? thanks for ANY help on this matter |
There are a few things that could be causing this that are more common than a fuel pump failure. First step is to check for stored codes.
stored codes
Ok so i checked the CE light and received the code of air flow meter is the MAF piece if it is I guess I might have to look for a MAF it only posted the one code 2
times it died again after I had checked AND CLEARED the codes any help?? |
Do a search for cleaning your MAF, but you may also want to start sourcing a replacement...
maf fix
finally got a replacement maf from a person on ebay from a 92 svx it runs again but still has a small hesitation on accelerating could new maf be going bad also and what years did the mafs for the imprenzas work for the svx or do any mafs work from same years?
