How to diagnose F/R Hood struts??
Hi,
I am wondering how we can say whether the struts have gone bad or not?? I checked them and the passenger side front hood strut is leaking oil whenever I open my hood and ofcourse the hood drops down after a while(1-2minutes) and I have to keep it stay. and the reat struts seem fine but, the trunk falls down like a thunder. Its ok with me since I always close the trunk slowly, but if someone closes it since they dont know, they just close it as usual and it slams down which hurts me alot. So, whats a good solution for these struts. thanks, -Pavan |
My rear strutts act like yours. They hold the trunk open, but close with a huge thundering crash.
The fronts on mine were new not that long ago, and they work very well, I suspect you will need to replace either both or just the one front strutt.
Chris G 92 Pearlie, sold @ ~209k miles. Now owned by Tim. Current Ride, 1985 Honda Aero 80, stock 3024 klms |
It's a bit expensive, but you should replace all the struts. My SVX also had the trunk slam problem and even developed a few chips and cracks, due to other people letting it slam. The rear struts will actually keep the trunk in almost any position when new. Now when I let go of the trunk after 3/4 of the way, it gently floats down, I actually have to slam it myself if I want it to lock. On the front struts, if they're not able to keep the hood up for very long now, it's a sign that both are bad, and they won't work at all when the weather gets cold.
KuoH |
The best thing is to replace them. There is a tube that can be added so the hood will not slam down, but that is just to keep it in the up position. The best thing to do is to replace them. You can buy used, but then you will have to replace them again when those go bad. Good luck.
New struts on a trunklid without a spolier will let the trunk stay at almost any position without falling. The added weight of the spoiler should let the trunk close more than halfway before it very gently falls on its own.
From the closed position, you should be able to lift the trunklid easily with oneor two fingers; the struts doing most of the work. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 06-04-2006 at 05:50 PM. |
so, what would be a best bet to buy those struts new and at a reasonable price (other than subaruparts.com)???
thanks, -Pavan |
