Engine pics
I have been working on everything else on the car and the engine here and there in between. Sorry for the crappy photos it does look better in person.
For those curious it has Grimm Speed ceramic coated throttle body, intake (pnp too), refurb heads were purchased from AWD before they shut their doors, Perrin lightweight pulley, and blue silicone vacuum lines may go to black later but blue was what they had. Probably some stuff left out but not much more left before it is ready for install. Again crappy photos but gives an idea, and don't mind the mess in the garage |
Re: Engine pics
Wowww, where will that go? Your living room?
Or a museum... damn that is pretty.
Re: Engine pics
Thanks guys, actually the block itself I did scrubb it down pretty good. The heads were pretty clean but I cleaned them up and painted the valve covers black with engine block paint. Gives it a nice dark look and pretty much matches the ceramic coating on the intake. For some of the parts I used a paint called alumi-blast (I think that was how it is spelled) makes the pulleys and steering pump look like a dull aluminum. All of the timing covers are new, replaced those when I did the HG, waterpump, and timing belt. I had other fuel rails cleaned up and painted but was having so much trouble getting the injectors out I went with the set up I got from Mike621 a while back. Some of the hardlines for the oil and such were sand blasted and painted. The fuel lines under the manifold were blasted and painted with the alumiblast.
I am thinking of doing the wrinkle coat on the oil pan, but haven't decided for certain. I just need to get the oil pan gasket, exhaust studs, and spark plugs and she will be done after installing the new flex plate. These will be installed then too. Engine install will have to wait. I recently got the 4.44 trans installed and steering rack (minus tubing). |
Re: Engine pics
Looks good but won't it make it hard to locate leaks? Not that these cars leak I like the headers.
Re: Engine pics
There is no Oil Pan Gasket, so all you will need is some silicone
Looking really good though, same basic look my engine will have once completed . Very well done, sir. Good luck on your reinstallation, try not to scratch the pretty paint EDIT: when you replace the flex plate, if you have not already done so, do the rear main seal. Might as well since you will be right there. (unless you completely tore the block down and/or did this already.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
Re: Engine pics
part numbers on perrin pullies??? are you using OEM belts??
Re: Engine pics
Thanks guys, the thing is I know every flaw well enough that I can still see them. Not that there are alot of bad flaws just things I wished I had the time and $$ to still address. Oh I also went through the wiring and put new protective tubing on them and fixed some of the routing I didn't like.
The headers I know some disagree with my choice to have them made to stock specs rather than full length custom, but that's ok it will look good either way. I just couldn't see putting the heavy rusty stockers back on. If I get HP gains cool, if not thats ok too. As for leaks, thats the beauty of having a clean engine or clean car. You always will know when something leaks and where it is coming from! lol. Since the forum has been a bit slow these days I will add this part too and get opinions. I suppose this part should go under mods or Q&A, I suppose it can be moved if need be. Suspension. Here is the set up I am going to be modifying to fit. I know the rears are almost direct bolt in. Some of the spindle mount will have to be cut down to fit but only a couple of mm I believe. The fronts I am thinking up ways to mount the front sway bar link. I also want to go with an adjustable link similar to what Nevin did for the rears. Any ideas or observations on how I should go about mounting the links would be helpful. |
Re: Engine pics
thats definetly car show display right there, ask subaru if you can display it at their exibits to show what they made in the past.
