When does the timing belt need changing ?
Has 112K on the clock. Checking the prior owners dealer's records, the timing belt was changed at 85K. When would it have to be changed again ?
Thanks, Wayne |
Should be good for 100k, as long as you don't have any major oil leaks up front......but doubt your waterpump will last that long
Heya Huck,
Mine was done at about 68K and I have 115K on there now.. It HAS been 6 years since it was done though. I am planning on doing the timing belt with a tune-up as well in a month or less. Would you suggest replacing the water pump at that time as well even if it's not bad? Thanks a bunch -Daniel
Insert Witty Quip Here... No more subie Current Cars: 96 Chevy Caprice Impala SS clone 93 Chevy Full-size blazer Soon: 2002 Honda CBR 954RR |
I would, as several people have had the water pump go out at around 120-130k, and if it goes while you're driving it, it can cause t-belt idler bearing failure, and end up costing more to repair later. I'd recommend cam seals and crank seal and water pump if you're doing a t-belt and have over 100k on the motor.....the seals are only a few bucks... Easier to do it all while it's apart than tearing it down twice...
Thanks for the help. Any idea what's a reasonable cost to do the timing belt, water pump and seals ?
Wayne |
I usually charge about $125-150 (plus parts)....Subaru charges about $450
