speedometer
odometer working..speedometer NOT working ?
Re: speedometer not working
Carl,
I will check in the USA service manuals tonight, I am sure this has been noted before? Anyone.... Also edit your title to make more like mine....
Re: speedometer
Got the same problem with mine. It started after I had a new trany installed. The car sat for three years before the install, I suppose the down time could have affected the speedometer.
[SIGPIC][/SIGPIC]Kenyatta The farther backward you can look, the farther forward you are likely to see. -Winston Churchill My baby: 94 lsi My fast baby: 2001 Suzuki Marauder My new baby: 2010 Subaru Outback |
Re: speedometer
speedo not working at all or not working above 50kph ?
Re: speedometer
sometimes speedo sticks at 10 kms and sometimes nothing...carl
Re: speedometer
vehicle has been stored for 8 years.
