Rough Idle
My SVX has a rough idle sometimes. When it first warms up up and the tach comes down to normal idle its just fine. But after driving for a while it seems to get rough. Its just as rough in drive, park, or neutral. I wonder if the fan could be on and that could cause it to be rough for some reason? I figured I would ask you guys first because there is a plethora of knowledge here.
Thanks Ownbot |
Sounds like you may have a vacuum leak somewhere. I would go over your lines and make sure they're all connected properly. Also, check your TPS (Throttle Position Sensor) voltage, that can also lead to a rough idle if it's set to low.
