5 mt wiring questions....
I am finishing up a five speed swap in my '95 (with a '98 Legacy Outback trans,) and i have been referencing Tom's write-up (which has been very helpful, especially the pics as I bought what I thought was a small-car cross member that ended up with mount holes in mid-air next to nothing...) and I have some questions with the wiring.
1. Speed Sensor: Theres a plug coming through the firewall on the pass. side that plugged into the A/T right behind the bellhousing with 3 wires (yellow/orange, purple/white, orange/yellow,) and 3 wires coming off the pass side of the M/T that are green/black, red/black, black/red. Are those the correct wires and if so in what order do i connect them? 2. Reverse: There is a sensor where the shifter linkage goes into the M/T that i would imagine is the reverse sensor.. the wires are both black coming off the M/T but after the plug (from the Legacy) the wires are green/black and black/red, and if they are reverse wires where do they go in the auto harness? 3. ?? There are two more wires coming off the M/T just forward of the Reverse?? sensor that are both red/yellow on the M/T and then tan/yellow and black/yellow after the Legacy plug. What are those and do i need them/where do they go? 4. Neutral safety Switch: In toms write-up he says to connect the top switch from the clutch to the blue/white and black/yellow wire in the A/T harness which makes perfect sense.. if i could find a blue/white wire in the A/T harness, i could only find a solid blue wire, but it was beside a black/yellow one so i guess its the right one? Thanks for everyone's help, this forum is the best if i have ever wondered something about the SVX its been on here! |
Re: 5 mt wiring questions....
check the quote for the answers, hope this helps Tom |
Sweet! Thanks for the fast reply, this clears it up alot! Thanks a bunch for the help (and the write-up)!!
So just how hard is the swap? Been thinking about doing it but I'm not sure how difficult it is.
For me.. it would have been alot easier if I had all the right things, the cross member was a biggie. I had to modify the pedals alot more than I thought, other than that it really wasn't too bad. All the wiring was really easy after above clarification and the only thing left is puting it all back together.
Which leads me to my (hopefully) last question.. Which computer is the TCU? I don't see anything differentiating the two under the dash.. |
The ECU has yellow connectors, the TCU has black.
