bad head, should i replace whole engine now?
so my mechanic got back the heads from the shop ( they were supposed to clean the heads) but when they put them on the compression machine to test them, it showed some cracks inside and out side the heads. my mechanic told it would be better replacing the whole engine just in case the block was damage. is there any other option to fix this?
Re: bad head, should i replace whole engine now?
Well what I would do is test the block for damage. Is your car burning oil by any chance?
You can either change the whole engine or buy a couple of used heads and put them on.
can you post pics of the "cracks". what did you have the car at the shop for in the first place?
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it. |
Compression test on the head? Magnaflux tested maybe? This post needs to be a little more clear before any advice or suggestions are made.
Tom |
Sounds like another shop that hasn't a clue...
Keith |
Different areas of the country use different terms... I just want to know what the hell they were talking about
Tom |
i hope so.... |
Pick up your old short block, and all other parts. Bring it all to my shop and I will install a pair of rebuilt heads. I will also check your block for any issues
Tom |
<<i guess, for now im just letting this mechanic finish this job since i already started w him but i will go to your place for other stuff since i need to fix her up little by little. how far are you from my place>>
did you get the pics of the cracked head(s) yet?
Evil, you'd better go to Tom's place, in my opinion better to let someone who really knows his way around the SVX fix it up for you than letting a "general" mechanic do that.
Just my 2cents.
i talked to him. i will be taking the car to his place next month.
