SVX suspension question
Hi all, New to the board and looking at picking up a SVX. The one I'm looking at requires some new suspension. I was wondering if the struts and springs from either the Impreza or Leggy models would bolt up? I'm on a bit of a budget with this car and I know several Impreza and Leggy owners with suspension parts for a good price. Any info appreciated.
Thanks Roger |
svx suspension parts are svx specific. i have read something about i think imprezza suspension working but having modification - which is what you dont want to do.
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
the big differance, that i know of is that on the front the sway bar bolts to the strut on the svx, and to the lower control arm on the imp/leg, so the front struts are completely out of the question, unless you want to weld brackets to your new struts(the guy i talked to said it was a bad idea, they kind of explode, but he could have done it wrong), you can get koni adjustable inserts for about what it would cost you at the dealer, also i believe that some models came with an adjustable sport suspension, that is oem parts only
hope this makes sense, and helps
1991 xt6 eg33? 1993 gc track car |
Take a look here
http://www.subaru-svx.net/forum/showthread.php?t=39540
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles My WRX's Cardomain Page |
Thanks for the info. I guess I'll just see about sourcing out a used set for now, or if I can find the Koni setup locally. I'll see what happens.
Thanks again. |
mychailo sells koni's
mbtoloczko is his tag
You'd probably be intrested in this thread...
http://www.subaru-svx.net/forum/showthread.php?t=39540 Bolt up system on the way, fully custom. Might as well improve it if you're going to replace it, right?! Not to mention we need more people... hehe
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
Hehe I know. Figured I'd make another plug though...
