Learned something new today
Today I was on the phone with a couple of knowledgeable people at the Technical and Performance Division of SOA (a part of the TechLine). These are the same group that reviewed and approved my alternator wiring modification.
Seems there were two differently designed transmission pans for our cars. The original pan, PN 31390AA030, was designed to be used with the transmission pan gasket. Used by the factory from the beginning of production of the 92's until about 5/1995. From mid-1995 until the end of production, Subaru started using RTV sealant from the factory instead of the gasket. The tranny pan was slightly redesigned to accommodate this. That part number is 31390AA060 Don't have the exact VIN for the changeover. I pursued this because svxfiles was going to drop the pan on my 96 Polo to change the internal ATF filter screen and told be someone had already dropped the pan, because it had RTV sealant instead of a gasket. I told him I bought the car with 42,000 miles and that I have complete records of every service ever done since delivery (with 24 miles) to the original owner, and that nothing was ever done to the transmission. My Mfg. date was 11/1995. This now makes sense and clears up the mystery. Using a older pan with RTV may not be a problem, but using the newer pan with just a gasket could cause leakage. Svxfiles talked about the gray and red sealant the Subaru uses. I will try and find out if they know what color was used from the factory. Can any of the OBDII owners confirm this? If your tranny pan has never been dropped, it should have RTV sealant. My pan has never been off and has never leaked a drop. This information may be of use if you ever need a new pan. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 02-12-2019 at 02:49 PM. |
Re: Learned something new today
All of the remans I've come across were held with sealant as well. Even at low mileages. Never really thought anything of it to be honest. Figured it was some type of change. I usually always use the gasket and a light bead of silicone on the pan side. Shouldn't need silicone at all on teh transmission side as that's of course a machined flat surface. (or should be unless some moron took a screwdriver to get rid of the stuck on sealant)
I had the same thing done with my 97. Mine had a gasket but they didn't have one on hand.
so they used fugi bond http://www.oakos.com/Merchant2/merch...Code=004403007 |
When is OEM ever cheap lol
My '97 has an orangish-red rtv sealing the pan. The original owner (my dad) doesn't remember having any transmission service done, at least not in recent years. I'm betting mine has never been cracked open.
I guess that means a transmission service just got moved to the top of my to-do list. ![]()
Jon 1997 SVX LSi Bordeaux Pearl 1995 SVX L AWD Polo Green - 277k miles 1986 Pontiac Fiero 3.4L Twin Dual Cam V6 Last edited by Coan; 08-12-2014 at 03:53 PM. |
The pan on my 96 polo has never been dropped either. Regular fluid flushes and recent tranny drain and fill with synthetic by svxfiles.
At 138,000 miles, all is good. Tom did not even recommend changing the original internal screen. Evidentally the screen does not catch that much. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 02-12-2019 at 02:47 PM. |
