limp home feature
i was looking at a svx info site and saw there was a 'limp home' feature. anyone know what that is? i did a search on 'limp home' and found nothing. thanks.
i guess a limp is better than crawl. |
Explanation
Mike 92 LSL Teal 103k 00 RS 2.5 Silverthorn Metallic 36k 68 Chevy Camaro 07 Forester XT Sport |
Cool, That's handy to have!!!
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
when my gear position sensor (on the side of the tranny) broke, it went into a limp home mode. Selecting manual, or 3rd, or 2nd, or whatever had no effect. The auto shifting worked fine, just no other features. I really noticed it because the dash indicator never moved.
that's good. if i ever have a bad sensor or some abnormality in a particular function related to the drivetrain, i can 'limp' home.
Re: limp home feature
Bump
I'm stuck in limp home mode, but via ECU and not the TCU. Any ideas on resetting it? I've unplugged the neg terminal and no joy. I've pulled the codes and only getting a code 24 for the aux air con valve. Which I've had for over a year. AND the car idles perfectly. Runs fine till 1500rpm. ANY ideas would be appreciated! |
bumped a thread from 10 years ago bud.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
I'm pretty desperate, need my car for work
If it runs OK till 1500, I would say that the Mass Air Flow sensor is not operating, and the ECU is running an set "idle" of tables that unit. Can't think of any other unit that would cause it. Harvey.
I was hoping I'd attract your attention Harvey! You've been a great help in the past.
I've already ruled that out with the 'unplug' test. Ran like crap and still wouldn't go past 1500. Tried gapping the plugs again, no change, tried the fuel pressure regulator, no change. Checked all connections, and changed oil pressure sensor for a known good unit. No change. Checked TCU connections, all snug as a bug. Adjusted TPS, no joy there either. |
