Hail damage
Well the couple of door dings I've gain since I got my JDM made me feel sad, but that pales how I feel by the Hail damage done now on the roof, hood, front fenders, doors and turn signal light
I'm guessing 50+ dents on both the roof and hood. Anyone know what is normally involved in fixing this type of damage and cost? I'll see what insurance has to say tomorrow if I can get through. Probably 1 in 3 or 4 cars I could see damage to on my trip home from work.
1992 (JDM) CXD Ebony Pearl 90K km written off hail damage 1996 (CDN) Lsi, Polo Green, 296,000 km 2009 Legacy Spec B |
Re: Hail damage
if you are gonna get work done get it done soon b4 the "metal memory" keeps the shape of the dent and is harder to buff.
you coul try taking a hairdryer to some of em and carfully warm up the metal it might pop right out
Re: Hail damage
"Using dry ice to repair dents in car bodies caused by hail is an old trick. The idea is to freeze the dented area and then to reheat it suddenly. The change in temperature causes the metal to contract and then expand in such a way that very often any dents "pop" right out as if they never existed in the first place. Occasionally you may wish to lightly rub the area with 0000-grit steel wool if the paint has cracked, but other than that dry ice and heat can be a "miracle cure" for hail stone dings.
Read more: How to Use Dry Ice to Repair Hail Damage" http://www.ehow.com/how_4793357_dry-...il-damage.html
1991 SVX L JDM |
Re: Hail damage
"Step 1
Check your local yellow pages for a dry ice dealer in your area. Take a Styrofoam chest to carry the dry ice in. Do not touch dry ice with your bare hands. Step 2 Put on gloves. Place a chuck of dry ice on one or more of the hail dings and use a towel to help hold the dry ice in place. Make sure the dry ice is in direct contact with the metal of the car. You want the dry ice to freeze the metal. Leave the dry ice in contact with the metal of the car for a full two minutes. Step 3 Remove the dry ice (return it to your Styrofoam container) and immediately blow hot air from a hairdryer onto the frozen metal with the hail ding. The sudden change in temperature should cause the metal to expand and "pop" out, making the damaged area look as good as new. Step 4 Rub the area gently with 0000-grit steel wool if there are any tiny cracks in the paint around the dinged area. Wipe the area with a damp cloth and allow it to dry. " I have not used this technique personally, so I cannot recommend it from experience.
1991 SVX L JDM |
Re: Hail damage
Re: Hail damage
Ahhhhh, dry ice
I can tell you the temptation to misuse that stuff is overwhelming. If you happen to stuff some into a 2-Liter bottle with some water, I wouldnt hold on for long Curiously, dry ice (frozen CO2) is the only substance that sublimates, which is why it like to make sealed containers go boom. Observe le idiots:
Chris "A person convinced against their will, is of the same opinion still" New?? Find the downloadable SVX Online Service Manual Here RECOMMENDED READING for newer SVX owners Here some cool info if not fully accurate. Last edited by SoCal LS-L; 07-15-2010 at 09:02 PM. |
